Question about Protron PLTV-32 Television
Not receiving power
The television will not turn on. The power light is not on either. It appears that it is not receiving power, but the cord is good and the outlets are working as well.
  • Anonymous May 05, 2009
    32'' lcd tv light off .no power. cord good.outlet good watching when went dead....can anyone help?????
    question:Are Protron LCD TVs garbage or what?.My tv never did work like it was supposed to.
    Problem Solver:
  • 5 Answers
It may be the power inverter on the TV itself.
If it's still under warranty I would call the company you bought it from and ask them to cover it for you. If it's not, get a quote from a local electronics store that deals with TV repairs.
Incase it's not the inverter and is something else inside the TV (blown capacitors , etc) I would recommend keeping it unplugged until you get it looked after.
Posted on Apr 19, 2009
My onkyo HT RC330 will not power up at all. Have had problems past couple of months with starting it but if you played around with swith it would start. Now nothing.
Try resetting the AV receiver To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press 8 ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter Standby mode.
It is possible that the protection circuitry has been activated. Remove the power cord from the wall.. Disconnect all speaker cables and input sources, and then leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect only the power cord and set the volume to maximum. If the AV receiver stays on, set then the volume to minimum, disconnect the power cord, and reconnect your speakers and input sources. If the AV receiver turns off when you set the volume to maximum, disconnect the power cord, and contact your dealer.
If the standby light is lit it and the unit will not boot it is most likely that the protection circuit has been activated. If there is no standby light then check the fuses. These units check that the power supplies are operating near specification. If a capacitor or resistor in the circuit, or a broken solder connection the unit will shut down. Because of the temperature the thermal cycling around the power supplies a broken solder joint can occur. This will make for an intermittent operation.
Hope this helps.
26289825-owoa52fq3dbvw0lom3ojbzgr-3-0.jpg Failed resistor or capacitor
Sep 23, 2016 | Onkyo Ht-rc330 5.1-channel Home Theater...
Westington tv wont turn on
My tv is a Westinghouse**** Sometimes i move the tv slightly and the cord partially comes out at the side and i just push it in all the way and all is ok
Nov 30, 2013 | Westinghouse 46" Class LED-LCD 1080p 120Hz...
Memorex MVD2042 Unit worked fine yesterday, but today is not functioning. Standby light does not come on, and no functions work. The unit is receiving power (not an issue with the cord or power supply). I...
unplug from any power source. leave unplug for 15 minutes some capacitors keep power for a while so leave it unplug for a while. then turn back on. see what happens.
Oct 19, 2013 | Televison & Video
NO POWER
Need to know how many times the led is blinking.
Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
  • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
  • If the standby light begins blinking eight times, return to step 1.
6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
  • The initial setup screen displays if the above procedures were performed correctly.
11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
Hey there! Just replaced the lamp in my sony KDF70xbr950 and now it will not even come on I have 4 flashing red lights and then goes back to a solid red light can some one help!! ...
The LAMP light is flashing or blinking.Solution
If the LAMP light is flashing, first attempt to perform a power reset on the television. If this does not resolve the issue, then the lamp inside the LCD projection television may have burned out and will need to be replaced. If this appears to be the case, consult the Replacement Lamp Part Number table to determine the correct replacement lamp for use with your projection television.
NOTE: The LAMP light is not the same as the POWER/STANDBY light.
How to perform a power reset on a Sony® television.Solution
Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.Unplug the television power cord from the electrical outlet. Let the television remain without power for 60 seconds.Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.Turn on the television.
Sep 16, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Cannot program Dish IR remote l03602
adeline_roll
You didn't specify if you are trying to program the remote to your TV or receiver. Is it a replacement remote or did it just quit working? I have provided instructions on how to program to your TV or receiver.
Address to receiver:
Remote: All Other Remotes
  1. Go to System Info screen (depending on receiver - press System Info button on receiver panel or pull smart card out till System Info screen appears on TV screen).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you have any other questions or problems. Thanks.
Ray Calo
DISH Internet Response Team
Jun 23, 2011 | DISH Network IR Remote Control
Whenever i turn off the mains, i get a Demontration message after power on.
From the manual:
Demonstration Mode
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH
DEMONSTRATION PLEASE PRESS POWER KEY
WHILE THIS MESSAGE APPEARS IN THE
DISPLAY THANK YOU”
To cancel the demonstration
Press ?/1 to turn the receiver off while the above message
is being displayed. The next time you turn the receiver on,
the demonstration will not appear.
To view the demonstration
Hold down SET UP and press ?/1 to turn on the power.
Notes
• Running the demonstration will clear the receiver’s
memory. For details on what will be cleared, see
“Clearing the receiver's memory” on page 15.
• There will be no sound when the demonstration mode is
activated.
and...
Note: If the AC power cord is disconnected for about two weeks, the receiver’s entire memory will be cleared and the demonstration will start.
Mar 17, 2010 | Sony STR-DE445 Receiver
Power light comes on but no picture. Black screen
if the set appears dead ecept for the power light, unplug the power cord from the back of the set, wait two minutes, then plug it back in and try to turn on the tv. Doing this worked for me.
Jan 27, 2010 | Sanyo DP42746 42 in. Plasma Television
Kenwood KR V8080 receiver
if you sent 110v down the speaker wires & into the amp you most likely have damaged the audio outputs or the output ic. Look for a big aluminum heatsing & on one side you may find 1 or 2 ic's or numerous transistors, the ic's are hard to check, the transistors are easier to check, if transistors replace in pairs. also check for burnt /open resistors near outputs
Aug 18, 2006 | Kenwood KR-V8080 Receiver
Protron PLTV-32 Television Logo
98 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
