Question about Tasco Astronomical 302675 Telescope
Spider web or dust in a tasco lumina #110450 how do you clean it
  • 3,186 Answers
Blow it out with canned air--- and clean the glass like this--
http://www.televue.com/engine/page.asp?ID=143
Posted on May 16, 2009
How do I take off the front screen to clean it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 24, 2014 | Hitachi Televison & Video
There is four pipe that gas flow into it furance,only one ligth up,please need help!
Hello, sounds like you are referring to the burners. Usually when this happens the whole burner assembly must be cleaned, spider webs and dust clog up the burners.
Oct 06, 2011 | Goodman GMS90703BXA Heater
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and...
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Mar 20, 2011 | Sony KP-53N77 TV
Spider webs behind screen
Pardon me but do you mean the screen has spider web looking patterns all over it? Or are you saying that spiders have crawled into your set and spun webs to catch flies?
If you have a spider web pattern problem then something has impacted your television screen and it is broken. You can check and see if your homeowner's insurance covers this, contact a service provider to see if they want to buy the television for its parts, and contact Mitsubishi to see if they offer a discount or pro rated rate on a new or refurbished television for when things like this happen.
If the problem is that you have spiders in your television I do not recommend vacuuming it out. I have seen people's televisions go out after they attempt to remove dust and webs that way. In this instance I also recommend contacting a servicer and the manufacturer.
Jan 28, 2011 | Toshiba 57HX83 57" Rear Projection...
Spider webs Sony KDF-42WE655
I'm guessing they're inside of the Tv right? well what you could do is buy a can compressed air to remove all the spider webs and dust inside of the Tv :)
Jul 01, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do I dust inside the screen of a Rear projection TV?
Unplug tv first Usually you can pop the front screen off the set. There may be two hidden catches depending on the model. You may want to use two people for this. Once the screen is off removed the spider web and clean the back mirror with some windex, don't clean the inside of screen with any cleaner. Replace carefully the screen making sure it clicks back correctly
Mar 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
SONY WEGA SCREEN
take the back cover off and vaccum them out, then dust it. If you can take it outside, compressed air does the fastest job of cleaning out dust.
Feb 12, 2008 | Sony WEGA® KV-BM142M40 14" TV
Sider webs
Here's my suggestion: I have a 55" Philips HDTV and I live in an area known for excessive dust and more than a fair share of spiders. I checked online and found that there are usually 1-4 access panels that can be removed for cleaning, repair, etc. Here are my steps: 1. Remove the upper most panel (usually a trapezoid-shaped plastic "box"). There are anywhere from 1-4 "hangers" that, once all the screws are removed, will hold the panel in place while you are unscrewing the last few screws. 2. Remove the panel and clean with a lint-free cloth the entire inside of the panel. This is an area where a lot of dust and spider webs can be found. 3. Grab your vacuum cleaner and carefully clean away all the spider webs. Making sure you don't bump into the inside of the projector screen! 4. Spray a small amount of dust cleaner or window cleaner on the lint-free cloth and run the entire length of the TV. Clean all surfaces this way except the reflector (mirror). It is best to clean the mirror with compressed air (get it anywhere - usually in the computer section). 5. Using a flashlight or bare lightbulb, thoroughly inspect all surfaces for dust and spiderwebs. And, of course, clean anything missed the first time around. 6. Using a clean lint-free cloth (I find cotton underwear from Wal-Mart works the best), spray a very small amount of window cleaner (streak-free Windex, etc.) on the cloth and rub the cloth together until almost dry. Then, simply wipe all three lenses clean. 7. Replace the back panel and pay close attention to the alignment of the holes to ensure the screw goes back in the same way it came (if not, the panel could ultimately lose the seal and allow for more dust). 8. Allow for several minutes drying time before turning the set back on. Hints: 1. Clean the speaker area, too. 2. Repeat the process at least each 30 - 45 days to ensure optimal performance. 3. Use a small computer fan to circulate air behind the set if the area gathers excessive dust. They're quiet and can be purchased (almost anywhere - Radio Shack, Wal-Mart, etc.)with switches that are easily accessible.
Sep 01, 2006 | GE 46GW947 46" Rear Projection Television
Tasco Astronomical 302675 Telescope Logo
2,627 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
