Question about Maytag Neptune MDG5500AW Gas Dryer
Gas burner doesnt ignite somtimes
The plug glows, but half the time the gas wont ignite.
  • 3 more comments
  • franklc01 Sep 18, 2008
    Gas dryer runs but doesn't heat up every time. No lint in trap or in exhaust pipe. Can't hear the burner ignite.
  • billt456 Sep 21, 2008
    gtube glows but nothing ignites
  • jerryjj Oct 05, 2008
    My MAYTAG coin dryer MDG16CSBWW is starting as normal but after 20 - 30 second the gas flame goes off - the drum is still going and it looks like everything is OK but heat is not working.
    Replaced new main gas valve with both coils and same problem, replaced both sensors on the heating chamber and same problem --- running out of options --- can anybody help ---- what can it be ??????
  • Anonymous Feb 08, 2009
    Maytag gas dryer...coils replaced, but burner ignites and stays on for a little while then goes off. Clothes aren't drying. Any suggestions?
  • mikemcl2 May 11, 2010
    I have the same problem with my Maytag driver, but I hear a squeeking noise just when the igniter glows red. Would a faulty gas coil cause that noise or is something else wrong.
  • 164 Answers
Time to replace your gas coils. those are the two round things on the gas valve. chances are the dryer ignites when first started but as the dryer heats up the coils fail and as it cools again the coils work again. make sure you replace both coils
Posted on Sep 19, 2007
Gas oven/elec start glow plug comes on and remains on, gas burner does not light
I am not familiar with this unit but first I would see if gas is flowing, if so I would go with the glow plug, or can you switch with another burner. Normally you need a flame to turn off the igniter.
Aug 24, 2014 | Kitchen Ranges
No blinks normal running igniter glows gas comes on wont run
Check for 24 volts across the gas valve when Ignitor is glowing. If no, bad board. If yes, bad gas valve or blockage.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 05, 2010 | Goodman GMS90703BXA Heater
Oven wont light
Gas or Electric? If Gas at the bottom of oven where Oven burner is there is a glow plug ,or some might call ignitor. When it get a signal to ignite gas that glow plug gets hot and ignites gas. and that does goes Bad .
Oct 10, 2009 | Imperial Commercial Cooking Equipment...
GE Gas Range/oven Model JGBS16 The glow coil in the oven works intermittently. When it doesn't come on we find that turning the control knob on and off several time will help or if we start one of the...
could be a bad thermostat but it sounds most likely like a loose wire connection somewhere. if the coil comes on and doesnt quite glow as bright as it should, the glow coil needs replacing.
Oct 10, 2009 | GE JGBS17 Gas Kitchen Range
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Glow plug lights but does not fire gas everything
This is most likely faulty gas valve coils. These electrical coils are located just above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If faulty, the gas valves cannot open and the burner cannot light. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at once if any are suspected of being faulty. Hope this helped and best wishes.
Aug 08, 2009 | Dryers
Glow coil glows but wo'nt ignite burner. can
if you have used the self clean function you may have burned up the ignitor they are rated for about 1000 deg for just about a minute but when you clean it stays around 800-900 deg for about an hour or so. You may just need to replace the ceramic ignitor. as for the gas, the valve will only stay open for a few seconds, if the oven doesnt recognize a flame the gas valve will close.
Jul 26, 2009 | Maytag PER5710 Performa Electric Kitchen...
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Maytag Neptune MDG5500AW Gas Dryer Logo
246 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
