Question about Kodak Carousel 4400 Slide Projector
How do you replace the bulb on a Kodak Carousel 600?
I know how to open the compartment where the bulb is, but I cannot remove it.
    Scholar:
  • 33 Answers
This post is a few months old but in case this come sup again: Assuming you have a 4000 series projector, withdraw the lamp housing after unplugging the projector. THe kind of clasp will vary a bit but it's more or less in the centre of the lamp housing which is located at the rear, right of the projector. The housing will stop just before you pull it out entirely. If you must, pull it gently but firmly some more, but it's not theoretically required. If you pull it all the way out you'll need to be careful re-inserting it so check out how it slides in and out before removing the whole lamp module.
Over the top of the lamp you will see a metal , bent "spring" that pushes down on the rear of the bulb.The spring terminates over and beside the bulb, hooked into the lamp housing. Press down on it a bit and outward to unhook it. Now don't yank it up but gently and firmly pull it so that the back of the lamp rises with it. You may not see it at this point but there is a corresponding bit of metal spring under the bulb, pushing up on the back of the bulb (where the electrical contacts are). In theory this will bring the bulb up enough to clear the socket and you should see the two electrical contacts (prongs) of the bulb. In practice, sometimes the bulbs stick inside the socket. Replacements sockets are hard to get and can be expensive so if it sticks, easy off a bit on the upward pressure, gently press down a bit on the (cooled) bulb a the back, and try it again.
You may or may not need to put a small finger under the bulb to ease it out of the holder. These weren't the easiest to operate lamp holders!
When inserting a new bulb, just reverse the above, You may want to gently press (too hard may crack the socket!) on the back of the new bulb as it goes into the socket. You want that bulb in there firmly so it doesn't arc electricity, which will corrode the lamp sockets and the bulb's prongs. Be careful to keep the lamp as even (level) as possible when reinserting it so the bulb doesn't crack. On the off chance it does, most times it will still operate satisfactorily as long as the prongs are firlmy in the socket.
Posted on Aug 17, 2009
Why won't the bulb work on the kodak carousel 750H
Those bulbs do burn out eventually, and need to be replaced.
Oct 26, 2015 | Kodak CAROUSEL 750HAR ELH Light Bulb Lamp...
Slide continuously change
The clutch contact on your KODAK Carousel 600 Projector has either burned off from use (the projector is almost 50 years old) or is out of adjustment. Either condition will allow the continuous cycle to happen. Because of the projector's age, parts will be really tough to come by. I have attached a diagram to show you what the affected parts look like. Be sure to take extreme caution - - there is exposed electrical contacts all over with the bottom cover removed. Also, be sure to remove the lamp and all optics before starting this repair.
Jan 17, 2014 | Kodak Carousel 600 Slide Projector
Kodak carousel
Sure!! You can order the detatchable power cords from: www.micro-tools.com. Micro-Tools bought the entire inventory of Kodak Projector Parts when Kodak shuttered that business. Good Luck !!! Jim
Nov 22, 2013 | Office Equipment & Supplies
Kodak Carousel 600 Slide Projector manual
The KODAK Carousel 600 Projector has NO forward or reverse controls. To cycle the tray forward, LIGHTLY depress the SELECT bar. Reverse is accomplished by holding the SELECT bar down completely and rotating the tray by hand. Jim
Apr 03, 2013 | Kodak Carousel 600 Slide Projector
Kodak 600 projector has not advance button
You're correct!! The Kodak Carousel 600 does not have an ADVANCE button. To advance the tray you LIGHTLY depress the SELECT bar on the edge of the projector. There is no reverse capability, other than holding the SELECT bar down fully and rotating the tray by hand. Enjoy your projector!! Jim
Mar 09, 2013 | Kodak Carousel 600 Slide Projector
Kodak carousel 600 slide projector thermal fuse replacement
If the FUSE is still available (this model could be as much as 50 years ago!!), the fuse is wired into the 120 volt circuit near the projection lamp. Check with: www.micro-tools.com
for availability. good Luck!! Jim
Feb 22, 2013 | Kodak Carousel 600 Slide Projector
Need a replacement dek lamp with a asa code
DEK Lamps for Kodak Slide Projectors are almost always in stock at "Batteries PLUS Bulbs" retail outlets. If you don't have one of these stores in your area, try: www.bulbman.com
Jan 28, 2013 | Kodak Carousel 600 Slide Projector
Slide carousel rapide speed
The problem is caused by a mis-adjusted clutch contact. This adjustment requires some dis-assembly, so unless you have service manuals for the Carousel 600, I would recommend you find a factory-trained repair dealer.
Apr 23, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel 4400 Slide Projector Logo
804 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
