Question about Baby Gear
Peugeot 206 headlight bulb problem
I have a peugeot 206 glx, Y reg, the front passenger headlight keeps blowing after a days usage after replacing the bulb. i have checked the fuses but they all seem fine. please help
Are you fitting the correct bulb?
i have a 2001 206 & that takes H4 bulbs
regards
Posted on Mar 03, 2009
SOURCE:
Peugeot 206 1.1 x reg, what causes a build up of pressure in the engine please
Check for a blocked PCV valve and lines as this the unit that vacates any build up of pressure in the engine from ring blow by from compression
Feb 21, 2014 | Cars & Trucks
Cant reverse car it goes up in the air more on passenger side .... tried pushing it back out of gear but cant peugeot 206 1.6 GLX
It would appear that there is a brake jammed on one side. Probably a park brake stuck on. jack up the car on the side and see if you can turn the wheel If not the problem will be in that wheel
Aug 03, 2013 | Motorcycles
I have a peugeot 206 v reg, I've had this car for
Not a Peugeot expert, but it sounds like you are not keeping the radio memory alive when the key is off. Usually there is a circuit to the radio that is hot with the key off that keeps the memory for stations etc.
Sometimes this is the same circuit for interior lights or cig lighter.
Jun 26, 2012 | Cars & Trucks
Will a peugeot 206 2.0 cc complete front strut fit a 206 1.6 glx
If the only difference between the two is the engine size, they probably so. BUT, an easy way to find out would be to call your local parts store and ask them if each model of that particular car, each require or use the same part number for the front strut replacement. If they use the same part number, then you can more accurately assume that the factory part is inter-changeable. Hope this helps.
Jul 11, 2011 | Peugeot 405 Cars & Trucks
My speedo light has gone on my dashboard. I have a Peugeot 206 GLX. It means I can't see how fast I'm going in the dark. Does anyone know how to replace the bulb? thanks
The dash board must be removed to install the bulb. This is not a big job but requires special skill and tools. Look in your yellow pages under "autoelectric shops" and then call around to the various shops until you find someone who will do this for a good price.
Oct 01, 2009 | 1986 Peugeot 505
Peugeot 206 cc fan belt change
hi ive a peugeot 206cc 02 reg, the STOP light keeps flashing ive checked the normal oil and water but alls ok so whats the problem still runs fine and temp stays where it should??? any tips??
Aug 28, 2009 | 2005 Peugeot 405
Peugeot 206 1.4 (54 reg) not starting after nock
it should be there mate it might be lower down to the rear of the battery (they are usually a black unit with a red cap)
Apr 06, 2009 | 2006 Peugeot 405
Baby Gear Logo
2,314 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Marvin
Marvin
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
