Question about General Plumbing
Can i make my motor run on 220
Model number is 106160 also says repulsion inouction motor
    Scholar:
  • 89 Answers
DONT KNOW WHAT KIND OF MOTOR THIS IS BUT : IF THE MOTOR SAYS 115/230 VOLT AC ON THE INFO TAG AND IT HAS A LOW/ HIGH WIRING DIAGRAGM THEN YOU SHOULD BE ABLE TO CONVERT IT. SOME MOTORS HAVE A SWITCH ON THE FRONT FACE WHERE YOU REMOVE A SCREW AND ROTATE A SHAFT. IF THIS DOESNT HELP GIVE MORE INFO. JODY
Posted on Apr 20, 2009
Wiring a ge motor 220; has three black wires
That's a 3 phase motor(ph3). And probably a 220v/460v? Or a 110v/220v, BIG difference! You'll need to figure out your supply voltage and wire it accordingly. Normally, if 220/460, all 3 black wires are hot legs, and this is probably what you have, because 110v will normally have higher amperage than what you posted. And if the motor runs backwards, switch any leg with 1 other. Hope this helps!
Aug 19, 2017 | GE Heating & Cooling
WHAT IS pOSTAL CODE REPULSE BAY, NU, CANADA
There are over 240 postal codes in Repulse Bay. The code for post offfice box 1 is:
PO BOX 1
REPULSE BAY NU X0C 0H0
May 19, 2014 | Computers & Internet
I have motor dayton model 9ncg4 now the wire is110 conected i need to conected 220 i need the diagram
I reversed start winding to reverse motor now it runs the right direction but it keeps starting instead of running smooth
Sep 27, 2012 | Dayton Wire Wheels Motor 2 HP 3450 230 V...
Jointer doesn't run smoothly
My bet is that the motor is designed for 220/240 (single or three phase), but you're running in on 110 single phase. If the belt were slipping it would sound like the belt on a car (you know when someone starts their car and belt is loose and goes "Sccrreeeeeee" until the rev the engine and make the belt catch up to the pully).
The power in wood working motors is such that it should be very difficult to slow down the motor if you're feeding at a slow rate. But, if the motor needs 220 and you're powering with 110, then the motor will have no power (the magnets in the motor are matched with the voltage - and if you have the wrong voltage you won't get any power and the speed will be very slow).
Typically the "home" or "residential" tools only run on 110, but if you have a larger unit they can be wired for 220 or 110. If you bought the planer used, they may have been running with 220 and now you're powering with 110 (or vice versa). I'd do a quick google search for your unit to see what it's capable of. Or, just take the model number of the motor (not the planer) and search for that.
Typically, motors can be run at 110 or 220 for larger wood working tools. Inside the metal housing where the wire feeds into are a number of wires to connect to. These wires have numbers on them (either a tag or printed on the wire insulation) and you attach them a certain way for 110 and a different way for 220. Sometimes you can even change the direction of the motor - SO BE CAREFULL IF YOU REWIRE IT! don't power it up all the way on the first try. Just start it and then stop it while the motor is still coming up to speed. While the planer is still spinning (even though the motor is off) feed your board in slowly and you'll be able to tell which way the motor is spinning. If you get the wrong direction on your motor you can shoot boards across the shop (or out into the street if you're in the garage - like I did).
Jun 23, 2012 | Delta JT160 Shopmaster 10 Amp 6 Inch...
I just bought a used hot tub with a Balboa Instruments model WL T-Pro motor. The cord from the motor has been cut and the people who set the spa up for me wired the cord into a 220 plug. I don't have a...
There are electric motors that run on ether 110 or 220 but wire must be changed on the motor to change from one to the other. Look on the side or end of the motor housing for a identification sicker or plate it well have the information that well tell you which it is or if it can be either.
Now for the bad news if it was sit up for 110 or if it is only 110 the motor is most likely fried.
Feb 01, 2011 | Home
Where can i find a new motor for a protech 4106 table saw
If you still have the old motor, use the info off of the motor label that describes the mounting configuration (this is the frame type). Do a google search for "Electric Motor NEMA Frame Sizes" for a good list of them. If your label is unreadable (or missing) search for the owners manual for your tablesaw - they usually have the specific motor model number.
The motor frame type is all you really need for making sure it will fit your saw - however, if the old motor was a 1 hp, and you install a 5 hp - you may have problems with the size of the motor hitting the table saw.
Also, decide if you want 110 or 220 volts. In general 220 is more effecient (3 phase is much more effecient). But I bet you'll want to stick with the original horsepower and voltage.
Then, do a google search for your motor. The frame for my motor is J56HC, it's a 3 hp and I use 220 volts - so my search is usually just "electric motor frame J56HC", but if I find too much garbage, then I search "electric motor frame J56HC 220 volts 3 hp". Once you find a motor model number (the motor I liked was a leeson 115048) then search for that. I found a great deal on ebay searching for this.
Dec 17, 2010 | Saws
I am installing a new pump and motor. the motor is 110/220 optional. I am 220. The connectors are A, B, L1 and L2. What goes where for 220. Thanks
There is always a wiring diagram on the side of the motor. If you want help with this one still, you would have to list here the exact model of pump, and the model of the motor connected to it.
Most common connections are to run one hot line to L1 and one hot line to L2.
You would want to confirm this on the motor housing though as some motors are different than others.
Nov 13, 2010 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I need to convert my 220 wiring back to 110 on my sears air compressor model number 106.173841 with doerr electric motor model 600678.
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
Jan 17, 2010 | Air Tools & Compressors
Runs 1 minute, gets hot and shuts off help!!??
Need a bit more information.
Are you saying that you have set it up for 220V or that you are running it on 220V?
Many motors can run on either 120 or 220, but you must check the leads and make sure they are jumpered correctly.
Are you running on 220 or 120?
Are there leads with numbers in the connection box that have wire nut or jumpers on them?
Oct 03, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Plumbing Logo
Top General Plumbing Experts
ka4iup
ka4iup
Gil Shultz
Marty Shuman
Marty Shuman
Are you a General Plumbing Expert? Answer questions, earn points and help others
