Question about Epson Stylus 680 InkJet Color Printer
Not printing in black
My printer won't print in black for the test pageor for documents. I have tried changing the cartridge and cleaning the head but still nothing?
  • zusa13 Dec 21, 2007
    My epson stylus cx 5000 printer will not print in black and white photos. I go to print preview and change the output box to color management. I set the printer to Black only and nothing comes out, just a blank paper. I have done trial and error with changing to gray scale to color, to black only and nothing. When it prints in grayscale I get a bluish tint. Please help!
  • 54 Answers
Turn off the Stylus CX. Load letter-size paper in the sheet feeder. Press the ink and ON buttons together and hold them down for about 3 seconds.
The Stylus CX turns on and prints a test pattern, which includes a nozzle check. If the print comes as = >
Nozzle check pattern with no gaps, and if its print in black then reinstall the printer driver
or => Nozzle check pattern with gaps and black doesn't print please send the printer for repair
Posted on Apr 24, 2008
SOURCE:
Even though my black cartridge is full, my black and white documents are so light they are unreadable. My color cartridges are close to being empty. Can this be the cause?
printers use all cartridges to get the correct colour even black
best get a new colour cartridge then realign the printer with a test pattern
Apr 05, 2015 | Office Equipment & Supplies
The printer will not print in black ink
Hi
Try going into Printing Preferences in the Kodak Printer Program and perform Maintenance.
You do not say which operating system you are using.
Start > (Control Panel) > (Category View) Printer > right click on the Kodak icon > Printing Preferences > Maintenance > Nozzle Check > Head Cleaning > test print > repeat nozzle check, head cleaning & test printing until problem is gone.
If this does not fix the problem, replace the black cartridge > head cleaning > test print.
You might need to perform head cleaning after every cartridge change.
I hope this helps.
Aug 28, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Won't print black, prints every other colour ok
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck....
Jun 19, 2011 | Canon Pixma MP500 All-In-One InkJet...
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
No Printed documents
Have you performed a print head cleaning? If not, follow the instructions below:
1) Press <Menu> on the panel repeatedly until [Maintenance] appears on the display
2) Press left or right arrow buttons until the cleaning setting you want appears, either [Head Cleaning] or [Head Refreshing]
3) Press the <OK> button.
Note: Head cleaning should be attempted first, and may need to be done more than once. Examine the results of the test page.
Head refreshing is more aggressive, uses more ink and should only be performed when necessary (ie. when multiple head cleanings failed to solve your print problem).
Dec 20, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Our lexmark Z705 printer only prints won't print black.
Clean your printer cartridge printer maintainence program or alignment or head clean
Jun 27, 2009 | Lexmark Z705 Photo Jetprinter InkJet
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Color ink not printing
Ahhrgh! Don't use windex. It contains additives that can harm the printer head.
I suggested this site in another post and it could help you.
Sep 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printing problem
Since it sounds like you've gone through all the steps to clean the print head, I would suggest trying a new black cartridge. There may be a problem with the one you have.
May 27, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus 680 InkJet Color Printer Logo
151 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
