Home | Sony | KP-46WT510 46 in. Rear Projection HDTV Tel... | Sony KP -46WT510 Con...
Sony KP-46WT510 46 in. Rear Projection HDTV Television
Problem for Sony KP-46WT510 46 in. Rear Projection HDTV Television
Sony KP -46WT510 Convergence Problem
By svbenson84 on Apr 19, 2009
Is it possible for a novice to replaced the IC's, Pico Fuses, etc that come with the TV Repair Kits which can be ordered online.
Is it difficult to get to the boards and do they need to be soldered; which could cause other problems on the board if done incorrectly? Can the entire boards be replaced instead? The cost?
Do you need the Sony Tech " codes " in order to do the manuel convergence after you make the repair. The projection TV is five years old.
Thank you for any help with this problem
Best Solution
posted on Jun 19, 2009
Very Helpful)
Ecollier2012
Rank: Guru  Sony Expert
Rating: 93%, 525 votes
Yes - If you are failry handy and take your time its a DIY project.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sony KP-46WT510 46 in. Rear
Questions and Unsolved Problems for Sony KP-46WT510 46 in. Rear
Do you recommend Sony KP-46WT510 46 in. Rear Projection HDTV Television?
Answer
Answer
Our picture is visible but is in blue tint. How much is that to fix, around? Is there anything... (More)
Answer
red light bye the power bouton but no pictuer
Answer
TV will turn on but no picture shuts off and red light flashes next to power button
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-46WT510 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
