Question about New World 60ECHDGm Electric Kitchen Range
Oven fault my top oven works but my lower larger one does not have you any suggestions. i do not have the user manual as the cooker came with the house. thanks.
0 characters
1 Points
My partner left the grill on on my cooker and now the grill won't stay on and there is no gas going through the bottom oven..any ideas what the problem might be?
Could be any number of possibilities, The user manual for your particular cooker (try Google the model number if you haven't got it) will have instructions on how to reset the cooker if it is a user feature.
It is very possible that a safety device has operated, possibly an overheat fail-safe. Such devices are internal, some are re-settable, others self destruct and therefore must be replaced, They can be separate components or may be an integrated feature of another component. They are sometimes a 'last resort' safety cut-out that operates when the design limitations of the appliance have been exceeded. They are often devices fitted to protect against injury or fire and may not necessarily protect against damage to the appliance itself. So even if the fault is due to the operation of a safety cut-out there is still a chance that any damage to your oven is repairable. The appliance should be professionally examined and tested before replacing the cut-out and recommissioning the cooker.
Nov 17, 2014 | Kitchen Ranges
Why is my electric cooker tripping?
there is a short in the wiring
May 15, 2014 | Kitchen Ranges
We bought a brand new dual fuel Rangemaster cooker and the adaptation of our bungalow and building works have now been completed and ready for the cooker to be installed. However, my husband ( who has a...
I used to have the same range with 2 electric ovens, but it is available with the lower large oven on gas and the tall oven electric.
The manual for theToledo with tall electric and large gas oven can be found here:
The manual for theToledo with both electric ovens can be found here:
The main product page for the toledo 90 can be found here:
Sep 16, 2011 | Rangemaster Toledo 90 (Dual Fuel) Dual...
For some reason my cooker keeps switching itself off, unless the timer is set to 12:01 it does this. It used to go off when the timer counted down to 8 mins, but this varies, and now it has a mind of its...
It sounds like you are setting a cooking time instead of setting the time of day. The oven wont work until a time of day is set. press the centre button (4x)until a red light flashes in the bottom right corner of the clock if you miss it keep pressing until you cycle through to the rh corner(note clock symbal) press + or - until you get to the right time leave for 12 secs then time locks in and your oven will work. the other flashing lites top left= cooking time bottom left =end time top right =timer function with no oven control. If this does not solve it the timer is faulty and requires replacing. good luck.
Oct 31, 2010 | Electrolux Insight EKC6049X Stainless...
Need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Jun 08, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Beko double oven electric cooker - bottom oven (fan assisted) doesnt come on, rest of cooker works fine
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 03, 2008 | Kitchen Ranges
My Tricity Bendix Strata SI 530 main oven does not work. The light in it also doesn't work. The top oven does though. Looking at the manual it suggests that the timer could be the problem, but there...
areas to look are:
oven selector switch and thermostat
mains terminal block - where mains input is connected. these can quite often burn out.
overheat stat
Jun 24, 2008 | Kitchen Ranges
MER6779BAW Range/Double Oven
I haven't checked anything but the heating element. The fault codes read F0-0, which means no fault but..... ?
Mar 03, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Fan oven stays warm
is the fan working when oven is staying warm? possible fault if you don't have an earth trip is a short to earth on the neutral side of the element
Mar 23, 2007 | Stoves 1100DFSID Kitchen Range
New World 60ECHDGm Electric Kitchen Range Logo
35 people viewed this question
Top New World Kitchen Ranges Experts
John Rodgers
John Rodgers
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
