Question about Microsoft Xbox 360 Console
Rrod Error Can u Help me fix the rrod?i have repaired it when i took it home it only runs once since then its showing three red lights nothing else.help please..
  • 3 Answers
198x is correct in the fact that if your XBox was purchased less than 3 years old AND you have the receipt, you should send it in to M$ for repair. However, they just put it back to the way it was, which is flawed so you should expect to have it happen again.
The issue is that the CPU, GPU and their HEAT SINKS get so hot, that the motherboard warps/flexes. Due to the high heat levels, the solder for the CPU/GPU becomes soft and when the motherboard warps, the contacts for them become disengaged. The CPU/GPU heat sinks are held in place with a X bracket that is held in place by tension. So when the boards warp, the CPU/GPU's are allowed to flex and pop up.
What the towel process did was heat up the solder again and HOPEFULLY the CPU/GPU would become reseated but often times did not. This method also poses a high risk of your CPU over heating and if this occurs, you are pretty much done.
What I have done to two of my xbox's AND for two friends and has worked is fix it myself.
I first ordered a kit from THIS SITE and used the tools and hardware to repair my first console. Then when I saw how easy it was, I went to my local hardware shop and got the equivilent washer and bolts and for about $5.50 I fixed my second system. Then I fixed additional systems for about the same cost each.
This kit will remove the posts on the heat sinks and will be replaced with bolts. The bolts, accompanied by the proper size and sequence of metal and plastic washers will fix the heat sinks firmly to the motherboad and will not flex with the motherboard when it gets hot.
The original kit comes with a custom cut tool that makes opening the console easier than it would be without. It also came with some CPU cleaner and paste but you can pick up good quality stuff at a PC Reapir shop.
I have used up the cpu paste it came with but I got more for a few bucks.
The site offers step by step instructions on their site and are very easy to follow. You will be required to increase the size several holes in the aluminum console case so you will need the right size drill bit. I used a dremel to increase the size and then to sand down the burrs.
All in all a very simple fix and the more you do, the quicker they get.
Good Luck.
Posted on Apr 19, 2009
    Problem Solver:
  • 11 Answers
Sorry to say it but there is no real solution to fixing the RRoD, if Microsoft knew this then it wouldn't really be a problem for any 360.
The common overheating towel trick or cooling trick does not permenantly fix the solution, it only prolongs the amount of time before it finally packs up.
The only way to truly fix the RRoD is to send your console back to Microsoft for them to replace whatever has overheated in the first place.
If your console is under 3 years old then it is still in warranty as Microsoft have extended the warranty from 1 year to 3 years to anyone who has the RRoD error. If it's older than 3 years then I'm afraid you'll either have to pay for repairs or possibly new console.
3 blinking red dots? what might have made this happen and what might i be able to do to fix it?
Microsoft has extended the warranty on xbox 360's for this very problem but time is running out. You can start by going to Microsoft's support pages.... http://support.microsoft.com/kb/907534
Feb 02, 2011 | Microsoft Xbox 360 Console
Three red lights around the "on" button and a green light on the power supply
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Jan 27, 2010 | Microsoft Xbox 360 Console
I have two red light on my xbox when u turn it on and nothing works?? the lights are the two left lights and the console turns on for 15 seconds then the fans shut off and red light blink?? any ideas any...
Here it is. The two red lights is a "general hardware failure" but I find most of the time it is the CPU's fault. This happens when the CPU is not kept cool enough so the Xbox shuts down to prevent overheating. Basically it's the same deal as the RROD. To fix it you should do this:
A) Send it to Microsoft for repairs if you're still covered.
B) Send it to a trusted Xbox Repair center. I currently run one called DRAGONF1R3 REPAIRS.
C) Go online and purchase a RROD X-Clamp fix kit. This should come with instructions on how to fix your X-box 360 by yourself and the Hardware you will need.
These are your three best options. If you need more information on my Repair service feel free to e-mail me. (my e-mail is in my description)
I hope I helped you out.
Jan 24, 2010 | Microsoft Xbox 360 Console
Hi... i have three lights flashing? can you help please
itz rrod......
or may b due to power failure,
chck unplugging all plugs frm ur 360 n reconnecting it, if it works then its nt a rrod, if it doesnt ...
then itz rrod, u need to send your xbox 360 to fix it..
or need to get it xclamped:
here is the whole process to do a permanent fix *xlcamP* of rrod on ur xbox 360:
http://www.megaupload.com/?d=2LEW79G4
Dec 27, 2009 | Microsoft Xbox 360 Console
Scratched Xbox 360 motherboard
Usually if a motherboard has been scored or damaged.
( tracks or resistors/capacitors dislodged et,c )
The board is in the Bin. ( scrap ) unless the damage can be repaired. The RROD Or red-ring of death. Is usually due to the x-clamps fitted to the console initially, by the manufacturer.
Replacing the x-clamps, with a kit ( bolts/washers thermal Compound ) And 4 x heatpads recommended. Can cure the RROD. And in my own experience the 1 red light And E74 error.
Bottom line, if the boards scratched. it,s in the Bin.
Mike @ Compurepair.
May 29, 2009 | Microsoft Xbox 360 Console
Xbox 360 flashes three red lights and want do anything
Hi, click on the link below to help with your ring of death issue. this link will direct you to a site that has a step by step guide on fixing this issue. it is repairable.
CLICK HERE
May 14, 2009 | Microsoft Xbox 360 Console
4 red lights
its called the RRoD (RED RING OF DOOM). NOTHING YOU CAN DO. Sned it to micosoft, they'll send you a brand new 360 for free.
Mar 25, 2009 | Microsoft Xbox 360 Console
THe xbox 360 has three red flashing lights when you turn it on. Nothing else comes on. How much will this cost to fix.
Hi, this is a common problem known as the RRoD or the Red Ring of Death. If you xbox is still under warranty, call microsoft and they will fix it for you for free. Microsoft's fix is sometimes temporary. You can also fix it yourself permanently with a DIY step by step video guide with very easy to follow instructions that costs only $29. Click on this link and <a href="http://www.xboxtopsecret.com">Fix your xbox RRoD</a> today. Go to http://www.xboxtopsecret.com for more info.
Jan 19, 2009 | Microsoft Xbox 360 Console
Xbox 360
if its something like this call microsoft and tell them the light status..u will get a replacement..i got three such!! RROD damn!!
Nov 02, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
51 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
