Question about Dell Inspiron 1300 Notebook
Inspiron 1300 is dead
Just got a new battery for inspiron 1300 and it wont turn on now ithought it was the battery. Ihave just paid £100 and it still wont turn on help
  • Dave May 11, 2010
    Need more info:
    - did the laptop work fine with the old battery?
    - does it turn on if you use the AC power?
    - is the new battery fully charged? Have you tested it?
    Genius:
  • 1,689 Answers
Hi adele, thank for you using fixya.
with regard to your issue, there are many points you have to consider to be checked to have the laptop working again.
LaptopRepair101 have illustrated points where you can check to properly diagnose the device.
PLease click on this link: Laptop is dead, How to troubleshoot the problem...
Hope this helps, should you have other questions, please do not hesitate to let me know.
Posted on Apr 24, 2009
The inspiron 1300 will not detect the dell battary it says no battary
HI there,
Is there any way you can check this battery. Ideally it would be great if you could test this in another 1300 to see if it does the same.
I am thinking that the battery may be dead and you may be able to get a cheap replacement on eBay.co.uk,
I had a 1300 and this was my problem. I borrowed a friends battery and all worked well,
I hope this is helpful
Jul 28, 2011 | Dell Inspiron 1300 Notebook
Have a dell inspiron 1300 new battery was off about 2 weeks,plugged back in get slow blinking green light after all night wont come on when i push power button ???
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad
6. The motherboard could be defective & needs to be replaced.
Sep 12, 2010 | Dell Inspiron 1300 Notebook
Dell inspiron 1300 does not switch on
try unseating and reseating the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion.
If this doesn't do it then take out the hard drive and dvd drive then turn on ht laptop.
If after all of these steps you still don't get video then the motherboard is bad.
Aug 08, 2009 | Dell Inspiron 1300 Notebook
Inspiron 1300 battery
If you have replaced the battery with a NEW one and it doesn't charge, then you either have an issue with the AC adapter (If the sensing pin is bent or broken in the barrel of the connector, the battery will not charge) or the charger curcuit of the motherboard. If the issue occurs on a different AC adapter, then FLash the BIOS to current version. If battery still doesn't charge, then replace the motherboard
Jun 24, 2009 | Dell Inspiron 1300 Notebook
Dell inspiron 1300 wont work from the AC adapter
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Jan 28, 2009 | Dell Inspiron 1300 Notebook
Inspiron 1300 Laptop wont go on
I have seen this problem before. If you can take out your memory and set it aside for about 10 mins. Then put the memory back in. Keep the battery out and try connecting the laptop to external power. If this does not work then you probably have a blown power connector or motherboard. You can get a replacement board for about 175.00 and installed for a total about $350.00. You can get new laptops for that price or a little higher. I would take a look at the possibilities first before spending more money. Take a look on Ebay you will see your same laptop for less than the repair cost.
Dec 31, 2008 | Dell Inspiron 1300 Notebook
Dell Inspiron 100
I hooked it up to the monitor on my desktop and it worked sooooooo I need a new laptop monitor---I guess
Aug 24, 2008 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
Dell Inspiron 1300 Notebook Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
