Question about Samsung RS2534 Side by Side Refrigerator
Samsung RS2555SW Power Surge??
Power went out last night. Woke up to still cool fridge and freezer, but LED display for temperature control is not working. Unplugged fridge for few minutes and replugged...no luck. Will the fridge still work properly without the digital temp display? Anyway to set fridge temperature manually? Also, I assume this a main control board issue. Anyone know where this is located on this Samsung unit and if this is the right part to fix the issue??
http://www.appliancepartspros.com/part_details.aspx?part_id=4141293
Thanks
BIKER T
  • 909 Answers
SOURCE: The refrigerator side is not cooling.
ALMOST DEFINATELY YOU WILL HAVE AN ELECTRONIC CONTROLLED AUGER(MOTOR)CONTROLLING THE AMOUNT OF CHILL ENTERING THE FRIDGE COMPARTMENT. IF YOU SET THE FRIDGE TO MINIMUM AND LISTEN CAREFULLY, THERE SHOULD BE A SOUND INDICATING THE AUGER IS WORKING.( OPENING AND CLOSING THE FLAP). SET TEMP. TO MAX AND LISTEN. IF NOTHING, IT COULS BE A DEFECTIVE MOTOR OR FAULTY THERMISTOR(TEMP. PROBE).
Posted on Aug 17, 2007
bobotfel
  • 236 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
We had. n ice storm snow etc. Went thru about 15 times of power outage. The freezer side isnt cooling. Ice maker stopped. I have tried unplugging...plugging back in. Finally got ice maker to turn back on...
you have spent $1395.00 on a machine you hate
most people get rid of it after the first $500.00 bill as new fridges cost around $1000.00 and you get 2 years warranty
smart people with new fangled fridges power them through a quality surge protection device as well
Jan 23, 2018 | Samsung Refrigerators
Power surge brand new maytag fridge not cooling
That power surge probably burnt out the guse on the circuit board. I suspect you may need a new board unless you know an electricity geek who can replace the fuse. New I would check your warranty. That circuit board might cost $200. plus..
Dec 21, 2014 | Maytag MSD2756G Side by Side Refrigerator
Samsung fridge RS2555SW is not working. all temp lights are blinking. can you help
May be it needs reset. Unplug the unit for 12 hours and then reconnect to see if that makes any difference.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Samsung Refrigerators
The digital display on my rs2555sl Samsung stopped working and the fridge and freezer are not cooling. The fridge is only 4 years old. what could the problem be?
circuit board controling temp to both fridge and freezer is out. Could have been fried by an electrical surge or just a badcircuit board.
Sorry
Dave
Jan 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
We lost power last night and it came back on our digital display onthe fridge just has one dash and will not allow me to set temperatures
When the freezer is below -12 degrees, you will not be able to set the temperature.
Should be ok after a period of up to 3 hours.
Hope this helps
Sep 29, 2009 | Samsung Refrigerators
THe freezer is working fine, but the fridge is not cooling very well MODEL HTS22GBPBRWW
samsung RS2555SW the freezer temperature is 58 tryied to changed to -4 it goes back to 58
Aug 13, 2009 | Hotpoint Refrigerators
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
No display panel indications on Fridge freezer
We had the same problem due to a power surge- we pressed the power cool and power freeze buttons at the same time until it reset and it's fine now. Hope this helps!
Dec 29, 2006 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2534 Side by Side Refrigerator Logo
349 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
