Toshiba laptop, AC light flashes yellow 6 times, pauses, and repeats, will not start, have tried with and without battery installed
  • mrninja
    mrninja May 11, 2010
    the os will not boot? or the laptop wont turn on at all?
  • pontelemon
    pontelemon May 11, 2010
    This is an error code. I need to know on how long is each flash. There should be combination of short and long flashes for ex: long-short-short-long-short-short.
  • 277 Answers
BIOS codes are sound-coded, not LED based. This is a power controller issue. I have the solution for the non booting Toshiba that I wrote almost a year ago. This tutorial (written and pics from the repair of my m35) is applicable to laptops that shut down without any warning, laptops that turn on only sometimes, and laptops that simply refuse to turn on (LEDs blink, fan spins up for a second and then everything just goes dead). So if your laptop does not turn on, it goes completely dead within a few minutes after bootup, here's the link to the tutorial. The repair takes about an hour, there's no need of replacing any parts, reinstalling any software or any other thing. The only investment in repairing your laptop with this tutorial is your time. Basically, you can repair your laptop within the hour, without spending any money for any parts or software.
http://imateski.blogspot.com/2008/08/toshiba-satellite-m35x-motherboard.html
Posted on Dec 19, 2009
  • 61 Answers
Hello.
Please try with another AC power supply.
Posted on Apr 20, 2009
How do i determine if my ballast board or capacitor is bad in my toshiba hd tv model no 57HM167?
The chances of the ballast failing are small on this model. Count how many times the Yellow light flashes before it pauses. Then google 57HM167 and the amount of blinks. ie " 57HM167 Yellow light flashes 3 times" That will tell you what you need to know. You can also post it here and we can help. I suspect you have a stuck fan(the fans are monitored to see if they are spinning. If not, they will not allow the TV to start up). Or you have the cover for the lamp not installed all the way. There is a switch that the lamp cover activates and the the TV will not turn on without it secured.
Apr 02, 2015 | Toshiba Televison & Video
Toshiba satellite 1005 s157 laptop powers on and then turns off
it could be your ac converter in your laptop.. best bet would be to check the memory, take both the batteries out and try restart it without batteries.. if non of this works i believe it might be your ac con...
success
Jun 18, 2012 | Toshiba Satellite Computers & Internet
Error code orange light flashes toshiba a10
This indicates a motherboard issue, I would suggest a professional at this point to access if it can be fixed at a realistic cost.
Mar 08, 2012 | Computers & Internet
Yellow light flickers 4 times when trying to turn
If you don't get the flickering lights when you try to boot up with the AC adapter hooked up but no battery, it sounds like the problem is most likely a bad power adapter. Your battery is dead, and that's why you get the flickering lights, but the AC adapter is bad so you can't use it to power the laptop or charge the battery.
You can typically get a new adapter for $20 or so, or maybe even cheaper on eBay.
May 29, 2010 | Toshiba Satelite A10 Notebook
Toshiba Satellite A15-S127 won't power up
basically this may be the fault of ram or ram slot connectivity problem.
Aug 23, 2009 | Toshiba Satellite A15-S127 Notebook
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6...
Remove the battery and then press the power button for 45 sec then refix the battery and check that the machine is turning on or not?
If the laptop is not working on AC alone then this is the issue with the converter which is there on the motherboard.
Feb 19, 2009 | Toshiba (K000006610) for Satellite P25...
Computer won't start
Try this; Disconnect from the AC outlet rmove the dc plug from the jack. Remove the Battery and wait for 5 mins and plug in the AC-DC adaptor without the battery. If the Laptop runs, then wait for the Windows to totally boot up and while running try to put back the battery and observe if it still charges. If it still won't boot up repeat the procedure and before connecting the power remove the memory modules first and install 1 memory at a time. Also, if you can find your way to where the CMOS Battery is, I suggest disconnect it for about 10 to 15 mins. while Battery, memory, AC source are also disconnected.
Hope this helps.
May 07, 2008 | Computers & Internet
Blank screen, and blinking Power On light
My friend you need to replace the adapter as the adapter has gone bad and the battery is not charged so u need the adapter to be replace asap. thats for sure.
Regards
Moses
Jan 17, 2008 | Toshiba Satellite Pro 6100 Notebook
Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Sep 17, 2007 | Toshiba Satellite A55-S1066 Notebook
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
