Question about Nikon D80 Digital Camera with 18-135mm Lens
My D80 sensor scratch
i went to clean my camera sensor but i touch the sensor
it will be scratch :(
i buy it last 2 month
i have a warranty for it the agent repair it?
  • master848 Apr 19, 2009
    please help me
    i clean it by air pamp it have an some very small plastic touch the sensor may be.
    if i use the camera with F3.5 to F5.6 on the lens
    i see the scratch alpha but if i used it on F36 it will be very dark dot
  • 538 Answers
They will probably tell you these: "Physical Damage is NOT Covered by this Warranty"
Do you see scratch on the pictures?
Posted on Apr 19, 2009
Nikon D80 18-135 Lens, turned, remounted, cleaned contacts still will not turn on.
Call Nikon they will fix it for free if its under warranty
sounds like you went to a hack
Sep 06, 2012 | Nikon D80 Digital Camera with 18-135mm...
How to clean image sensor?
Follow the instructions in "The Low-Pass Filter" section of the manual (page 125 in my copy).Despite the warning never to touch or wipe the filter, if you're feeling brave you can use a good sensor-cleaning kit to remove stubborn matter. Any good camera store should be able to sell you a proper sensor-cleaning kit. (By "proper" I mean something better than Windex and a cotton swab.)
Apr 20, 2012 | Nikon D80 Digital Camera
D80 Digital Camera with 18-135mm Lens: I have a Nikon D80 with 18-135 lens. Just had err...
Having gone over a month with no response, I assume this is no longer a problem.
May 16, 2010 | Nikon D80 Digital Camera with 18-135mm...
Good pictures last month. Recently the color is
Your CCD sensor is going bad, I assume this is an a-75 or one of the many others that have a bad Sony part. They will warranty this issue for free even if you didn't buy it new. You must contact Canon in Japan.
Aug 15, 2009 | Canon PowerShot A85 Digital Camera
Any one can help me?
You will probably do more damge to the sensor if you try cleaning it yourself. I would return it to a professional camera store and have them do it. The sensor is very delicate and should not be messed with unless you knoiw what you're doing. Who pays for it, I have no idea. It's usually caused by dust when you remove the lens. That's a user problem, not a camera problem.
Apr 20, 2009 | Nikon D80 Digital Camera with 18-135mm...
Camera shutter issues
Dege,
You were hearing extra clicking or noise on long exposures right? I thought it was a dirty shutter so cleaning is what I thought should help. If your shop thinks it needs a repair that is a bit more pricey than thorough cleaning. If you suggest to them to consider cleaning the shutter mechanism so the parts move smoothly instead of repair / replacing how much less would that cost? Also would they think that would be enough, they may have seen some corrosion or misalignment that is snagging or hanging the shutter up, so it may need the extreme solution. If they don't recommend it or are insulted by your desire to think about another solution seek a second opinion, there's nothing wrong with trying to save some money esp. if you don't need that type of surgery, you know what I mean. If the other shop says yes that shutter is damaged and needs it. You know you have to do it eventually. Just find the best price wiht the shop that you like. As far as the normal wear & tear not really, we are shooting a D80 purchased in Dec 2006 at an average of 1,000 shots a month sometimes more. My wife is a photographer as has really used it constantly, it has been very reliable. Since your camera is more than 2 years old it is out of warranty. I will check Nikon for any sort of recall or issue with the shutter and get back to you.
randy320sgi
Jan 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
My camara Nikon D80 is having some trouble
Hey Nannayr,
You could bring your camera to any Best Buy™ store to have it serviced under the service plan you purchased for the camera, but if this is a Best Buy™ service plan it does not cover cleanings. I will say that camera cleanings are usually pretty reasonable in price, but make sure it is done by an authorized service technician or you run the risk of voiding any warranty or service plan on the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 25, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon d80
It might be caused by some dirt on your lens (either front or rear element) but is more likely to be dust on the cameras sensor.
There are a couple of sample images of what this looks like here and here.
Dust spots typically have a softish edge to them and affect more than 1 pixel. (if it is just the 1 pixel affected, which a very sharp edge, this could be a defective sensor).
Following the instructions in the manual for cleaning the sensor. Avoid touching the sensor (unless it is with a specialist sensor cleaning brush) and avoid cans of compressed air; use a hand-blower brush instead.
Matt
Mar 03, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 black spot center of photos
For D80, go to setup menu, select Mirror lock-up so we can see and access the sensor!
Sep 25, 2007 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
274 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
