The cartridge carriage keeps trying to work but it sounds like it gets stuck at one end and cant move back the over way. and then it computer say that the cartridge carriage has stalled
If you can remove the dust from the paper lifting area with the help of petrol or ip (all the gararis) and reinstall that portion, change the encoder (which goes from the carriage) and clear the round encolder with the help of wet cotton. Greecing the cartridge park area and then check it. If you find any problem then contact me at [email protected]
PRINTING PROBLEMS CARTRIDGES CAN NOT BE DETECTED PROPERLY Remove and return the Carts on the Printer do this twice then Use HP Software Cleaning Method. END OF LIFE MESSAGE ON EPSON PRINTERS Reset all counters using SSC Utility then Hard reset your printer by pressing the middle button (Paper Feed\Cancel) and power button for 4 seconds. CLEANING THE HEADS ON EPSON PRINTERS Hold down the Ink Change button for 5 secs STUCK PRINTER HEADS Check first if there are any paper hindrances on the printer carriage. Check your cartridge if they are inserted properly and Locks are in place. Check for lubrication on the metal bar where the carriage is attached to. Hope this helps =============================================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
carrige has stalled
Yup. Same problem.
