Question about Acer Aspire 5610-4648 Notebook
Toshiba touch pad driver setting
I am unable to adjust my touch pad setting. Recently the Icon seemed to to disabled from my start up bar. I am seeking any advice on how to correct this problem.
I want to disable the touchpad and use the external mouse exclusively
Some laptops don't have dedicated buttons but you can use Function keys (like Fn + F5 on Dell computers) to toggle the state of your touch pad. In the case of HP laptops, you can hold the top-left corner of the touchpad for few seconds and it will disable the touch pad - repeat this to re-activate it.
New laptop computers either have a physical on/off button to easily disable the touch pad or there's an icon in the system tray that lets you manage the various settings of the touchpad. If you don't have that icon, you can go to Control Panel -> Mouse Properties -> Touch Pad to enable or disable the touchpad.
The touch pad can also be disabled through the device manager. Type devmgmt.msc in the Windows Run box to start the device manager, expand "Mice and other Pointing devices", right-click and disable the driver entry that says Touch pad or likewise.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 30, 2011 | Toshiba Satellite P305DS8836 Notebook
Ha a Toshiba Satellite a100 I can not turn off the touch pad (as I only want to use the mouse). Both touch pad and mouse are working. the laptop had to be reformatted recently and its since then All...
If your computer have a, Synaptics Touchpad you can try these steps:
1. Access the properties of the Synaptics Pointing Device by right-clicking on the system tray icon at the bottom right-hand corner of the screen. If you do not see the icon, open your Control Panel and select the "Performance and Maintenance" option. Click "System", then "Hardware", then "Device Manager" to view the devices on your computer. Open the "Mice and Other Pointing Devices" selection.
2. Click on the "Device Settings" tab of the "Mouse Properties" window. The "Device Settings" tab is at the top of the window and located farthest to the right
3. Highlight the Synaptics Touchpad from the list of available pointing devices. Click the "Disable" button underneath the list. Click "OK" on the pop-up menu to confirm your selection. Click "OK" on the Mouse Properties window to close the window. Your Synaptics Touchpad will now be disabled.
Make sure to connect a USB mouse to your laptop before disabling the touchpad so that you will still have control of your pointer.
Hope this help. Goodluck!
Mar 23, 2011 | Toshiba Satellite A40-S161 Notebook
Dell touchpad tab gone from mouse settings. tried installing driver with no luck. Also tried uninstalling and reinstalling driver.
Customizing the Touch Pad
You can use the Mouse Properties window to disable the touch pad or adjust
the touch pad settings.
1 Click Start , and then click Control Panel.
2 Click Hardware and Sound.
3 Click Keyboard.
4 In the Mouse Properties window:
• Click the Device Select tab to disable the touch pad.
• Click the Touch Pad tab to adjust touch pad settings.
5 Click OK to save the settings and close the window.
Apr 06, 2010 | Dell Studio 17 Laptop
Asus touch pad too sensitive
There should be settings in the touch pad software on your machine or in the task bar that you can directly access to change all manner of personal idiosyncrasies related to HID. (Human interface device) Try also going into the control panel and looking for input devices, mouse, touchpad and adjusting the settings from within there.
Mar 11, 2010 | ASUS Computers & Internet
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
Can't disable touch pad
Windows hides rarely used icons. If your does, then the task bar shows a left pointing arrow < . Click it and look for the icone for touchpad.
If you cant find that icon,
In WINDOWS XP
1. Start
2. Contol Panel
3. Right click the Mouse icon.
4. Under the Touchpad ON/OFF thumbnail, put a check mark in the disable option.
5. Use the same procedure to enable touchpad
Aug 22, 2009 | Dell F3534 Touchpad
How do I set touchpad settings to inop touchpad when USB wireless mouse is plugged in
Some laptops have a Fn Key sequence to disable the touch pad. Look for the touch pad icon on your function keys (hand touching finger on a square). You can also go to the toucpad app by double clicking on the touch pad icon in the system tray and got to device properties to disable tapping - assuming issue is TPad interfering with typing
Jul 25, 2009 | Toshiba Satellite U305-S5097 Notebook
Deactivate the touch pad
Try holding down FN key and F( key. This activated and de-activates the touch pad
Apr 25, 2009 | Toshiba Satellite A20 Satellite A25 Series...
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Enabling computer mouse
did u hit fn key or botten above mouse turn the mouse on ??> buy usb one mini
Jan 16, 2008 | Toshiba Qosmio G25-AV513 Notebook
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
