THERE IS NO SOUND OUTPUT IN MY PC
I have problem that there is no audio output in my pc. there is no sign of volume control manager nor sign of realtek hd audio drive. motherboard i am using is asus M2N68-AM.so please help me out
  • aditya4510 May 11, 2010
    ARE U SURE THAT YR REALTEK AUDIO DRIVER IS PROPERLY INSTALLED
I had the same problem when i built my computer but it turnrd out i had my speaker plugged in wrong cause my volume mixer had a red x thru it so i took it out of the blue plug and put it in the lime one then i had my great sound. hope this helps.Brenda.
Posted on May 01, 2009
  • 531 Answers
Did you try to update drivers from here?
Posted on Apr 19, 2009
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
How to connect the gemini to the computer
Easy.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for REAL audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The Gemini's Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select Line In.
http://i.ehow.co.uk/images/a04/fa/r2/subwoofers-as-home-entertainment-set-1.1-800X800.jpg
The Gemini's Output (Record Master) would perform similarly if adapted to your PC's audio input, whatever that may turn out to be (usually Mic, maybe Line In).
Mar 12, 2011 | Philips Gemini CDM-500
There is a cross bythe speaker icon.When i click on it it says,No audio output device is installed. I have no sound at all on my computer. How can I solve this?
if you dont have any built in speakers you might have to get a removable usb sound card or
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 25, 2010 | Computers & Internet
No audio output. I 've re-installed sound drivers. But still there is no audio output
hope this helps
Nov 17, 2010 | Intel DG31PR Motherboard
No audio output devices
check to ensure the sound card is properly seeded and connected
Oct 25, 2010 | Computers & Internet
No Audio Output device on Toshiba Laptop
REINSTALL SOUND DRIVERS . DRIVERS U CAN GET FROM TOSHIBA OFFICIAL WEBSITE
Apr 10, 2010 | Toshiba Satellite PC Notebook
Often on signing on no sound from my laptop
"No Active Mixer Device installed".....The Sound and Audio issue of Windows.....the infamous issue being faced by many PC/Laptop/Notebook users all over the world....on clicking the volume control icon in the task bar near the clock.....or....Sound and Audio Devices Grayed Out in the Control Panel
Guys....the solution's very simple....This is a sure shot solution...101% guarantee...Just do this...
Go to Device Manager, select Sound, Audio and Games Ctlr expand (+) press the plus sign, go one by one on all those that show a speaker image...select each one by one and right click, and if it has the "uninstall" option...just uninstall. Dont do anything further....just shut down pc/laptop
Then...u need to go into system BIOS
1 - Start PC/Laptop...press DEL or F1/F2/Insert/Home key...this selection of key to go into BIOS depends upon ur type of PC in some Del key works in some F1/F2 key works to go into BIOS....you need to do this before the WindowsXP screen appears....get into BIOS...
2 - Scroll/go to On Board Peripherals...press enter...next screen....
3 Look for
A- "On Board audio"
B- "AC97 audio" or any thing that says "Audio"
C- "Look for anything that says "MIDI" with some numbers 301,205 etc in [ ]
just Disable all the above by using PgUP PGDN key Press F10 and chose Yes to save the setting in BIOS or use Save and Exit in BIOS
Let WinXP load...go to Device Manager...go to Sound Audio and Games Controller...check all those that you uninstalled earlier if they RE-Appear...It should NOT......Re-appear.....if it does then do the above process once more.
U are now all set for the next move....
U need to spend just 1$ to buy this product on Ebay...you can buy any similar product of your choice but it must have the audio and mic output ports like this one has...and must be able to connect to your USB port of your PC/Laptop
This below image and product name is only for your info, you can buy any such similar product available in your area....but it's must have the Audio and Mic output ports like the one on the image below and must be able to connect to your PC/Laptops USB ports...
"USB 2.0 Mic Speaker 5.1 Audio Sound Card ADAPTER #9340"
You can Google it and locate it where you can buy...
Connect it to a USB port, connect your speakers/mic to the correct audio/mic slots in this device....WinXP will auto install this hardware and you will get back your Volume Control Icon...and all functions will work in Control Panel (Sound and audio Devices)...8cea5f3.png
Nov 14, 2009 | Acer (54.AA806.001) Sound Card
No sound
the drivers of the system might be corrupted by virus or so, re-installtion of driver will solve the problem.
Dec 24, 2008 | Microsoft HP Pavilion DV6276US Notebook PC
Sound problem
if you have motherboard installation driver cd.
load the sound card driver again.
or download it from i net.
hope it solves the issue.
go to control panel
sound and audio devices.
audio tab
sound playback
select correct audio device ie souncard rear output.
also on task bar vlume control make sure volume is not muted.
for master volume and wave .
make sure speakers are inserted in correct output jack.
May 18, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
