Question about Nintendo Super NES Console
Dead RF-out on SNES and vertical lines on Multi-out
A couple of years ago I thought my SNES had gone all dead on me. I got no picture or sound when turning on the power. It turned out to be the RF Out (the RF cable works fine on another SNES) that had gone dead.
So I bought an RGB cable, and the picture is much crisper than with the RF connection. But, I get these annoying vertical lines in some areas of the games. For example, in Super Metroid the equipment screen and Norfair backgrounds are full of vertical lines. Other areas look just fine.
I keep thinking there may be some relation between the problems. Any ideas on how to proceed with the troubleshooting would be appreciated.
I've already ruled out the AC adapter, RGB cable and the games. They all work fine on another SNES. The problem must be somewhere inside the console...
/Daniel
    Problem Solver:
  • 19 Answers
The problem is likely in the IC soldered to your SNES circuitboard. The cheapest way to solve your problem is to replace the whole SNES circuitboard. These boards run about 20 dollars, Google part SNSPT007 or SNSPT009, depending upon if you have the older or newer version SNES. There is no soldering involved, so it should be an easy fix if you can open your SNES.
Posted on Sep 20, 2009
2 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: Playstation Portable How to Down load Games
Hi Yoyoscoob,
You will need a WI-FI Signal to hook up to the internet. Then go to www.playstation.com.   They have free games , Screenshots, wallpapers, or more.  .  The URL above will take you to Playstation Underground, and you have to open an account.  They will send you good coupons to save  money on real in store games. Playstation Underground is the coolest site. Leave a comment if you need to know more on this topic, I will respond
Posted on Oct 15, 2007
Snes -horizontal white lines and buzzing noise
the best bet is to obviosly try another rf cable or try anothe snes unit.
Jul 06, 2009 | Nintendo Super NES Console
Sound but, no picture on my super nintendo
I fixed the problem. It was only some dust in the connector, but I can't still understand why the RF out is broken.
May 14, 2009 | Nintendo Super NES Console
SNES works but no color.
Sounds like your AV Multi-out port circuitry is shot. Yest it with an RF adapter, and if it works perfect with an RF adapter, that is the source of your troubles. I'm afraid that the cheapest solution is to buy a SNES motherboard (about $20.00), which is a lot cheaper than a repair shop soldering in new components to fix it. It's not something you can do on your own.. Google SNES Motherboards type 1 or 2
Apr 08, 2009 | Nintendo Super NES Console
Vertical lines show up on my SNES picture of any game.
Do you have a third party AC adapter for it? If you aren't using the original one, check its voltage. Mine was a 9V instead of a 10V and while it allowed the machine to run, I got visual distortion effects similar to what you describe. If it isn't a 10V adapter, go to Amazon and get a real one instead of a cheap third party one. I got this one (http://www.amazon.com/gp/product/B00009ZKWC) and it works great!
Mar 16, 2009 | Nintendo Super NES Console
Vertical line of dead pixles on Olevia 237T LCD HDTV
Replace the screen. It is faulty and is covered by your extended warranty. Any problems, contact your Trading Standards Office.
Mar 20, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Horizontal Line through middle of TV screen
That sounds like simple ring-cracks in the vertical circuit, most likely the vertical Ic itself... On the printed circuit side of the Tv look at the vertical Ic and examine it carefully under some magnification where each pin of the Ic solders to the board. See if you can find any cracks in those solder connections.
Bill
Feb 04, 2009 | iLO V27DMBX Television
Vertical lines obscuring image
The matrix is dead. Probably because of an intensive light got into the lense while the camera was in night mode. It's dead. Nothing can be done.
Jul 24, 2008 | Canon PowerShot A80 Digital Camera
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
No Picture
Well hard to say really without more to go on so I'll just be able to guess as what i've seen or had with this set. Most of the time when you lose Picture and still have sound its a vertical sweep fault. The set cuts out the brightness so the tubes dont get burn lines in them. Another fault could be with the HI Voltage distribution block. Now to fix it if you know how to read a schematic then you can buy one get a multimeter and start taking some voltage measurements around the Vert output. If you never done anything like this then You'll have to decide if you wanna spend more money on a sets thats only seven years old? Good Luck
Apr 24, 2006 | Sony KP-41T65 41" Rear Projection...
Nintendo Super NES Console Logo
1,236 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
