It is a hp laserjet I bought for a friend on ebay... have connected it to computer, but it flashes on the screen either:
PC load letter
or 18 AUX NT Rdy
Any advice!
To use the printer with your computer, first you have to install the drivers and make power cable connection. HP LaserJet 1018 has USB connectivity. So, you have to connect it to the PC via USB Cable. HP LaserJet 1018 Drivers & User Guide Visit the above links from HP Official Support and download the Drivers for your Model of the printer and Operating System (e.g. Windows XP) and user manual. Double-click the downloaded driver file and follow the on-screen instructions to install the printer. Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Don't forget to convey your feedback CreativeTECH
First thing to do is to turn off the HP. Clear out any print jobs that are sitting on your computer print que waiting to be printed. Turn the printer back on, wait about 1 minute then try printing again. If this does not work then clear the print job again and reboot your PC. Try printing again. If still you can not print then reply here with how the printer is connected to your PC. By USB cable? Ethernet? etc.
Thanks
on your desktop go to printers and share your printer. then from your laptop go to printers click add new printer. then choose a network printer and click find or search to find the printer conencted on your pc. the pc has to be turned on in order to print
This is not a printer problem. You have a computer problem. In ALL cases, the printer is told what to do from the computer, it does not report TO the computer.
dear friend,
when the printer give you a yellow flash that should be means a fault happen so you have to do the following:
1- check if any messages appears on your computer when you trying to print something that should be help you. if not go to step 2
2- black paper may be come from the (P.C.R.) that is the charger of the drum, so if you can open your cartridge and check the charger at the op of the drum that will be good and if not you may change the cartridge and check again.
3- Also, you can release the cartridge and look inside the printer may be you can find something wrong or something need to fix
4- Other wise go to hp help center
first of all remove the power cable and rmove the usb connection or parallal connection from the pc. Then conneted the power and usb cable. you need to open the case to remove the printer cartise. and add the cartise. Start your pc. give print command.
i think my friend that there is no solution for your problem... i heared this problem a lot o f time...but noone can fix it... i think that hp fault for this problem.. these printers are problematic
Use any printer parallel 25pin convertor to USB cable and connect it to pc or notebook Connect both ends from pc to 6L printer Go to website to choose the correct O/S driver for installation http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=14974&lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=18972&prodSeriesId=25476 Use virtual USB port005 for printer 6L Bi-directional option can be ticked Click apply and ok Unplug and replug the USB cable Try printing a test page,
I have tried it, the vista download drivers works on vista, no problems in printing at all, advise from http://www.bebo.com/andythoo
The printer screen reads: chosen language not available
