Question about NEC VT460 Multimedia Projector
Blue/Green hue at the outer edges
Hi, I have just bought a NEC VT460 projector, for absolute peanuts. The current lamp is 80% used and I have stripped down the projector and cleaned off all the lenses (tons of dust !!) etc, which has improved the light output, but I have a green one side and blue the other side hue creeping in vertically at the sides of the screen. What needs adjustment to bring this projector back into line !!! Is there a service manual available ?? I have bought a new bulb, but want the projector to be working properly before I install it.
  • joneseybo383 Apr 19, 2009
    Also, does anyone know how to strip down the lens housing for cleaning, the part where the R,G,B inputs are. There are 2 further lenses inside which I cannot access ??? and are full of dust.
  • joneseybo383 Apr 21, 2009
    Right, I bought a can of Compressed Air and gave the LCD panels a thorough blast and I appeared to have a misaligned/damaged fly eye lens, which I repaired and realigned.
    The projector is now almost 100% better than when it arrived.
    My only problem now is adjusting the convergence which is slightly out. can anyone advise on how this is done. I am a radio/electronic technician so have access to some test equipment if required and am obviously technically minded.
4 Suggested Answers
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
SOURCE: NEC VT460 issue with RGB
Dear please set the resolution of your PC or Laptop ,so that it can give O/P at same resolution as projector. For issue regarding resolution supported by Projector go through manual of Projector.
regards,
rakesh Kumar
Network Support Engineer
Posted on Nov 12, 2008
  • 438 Answers
SOURCE: We want to do the
There are no dealers in Hydbad as per the site below. Given below that is the cust Helpline number and email address.
http://www.necindia.in/m_local_dist.html
Customer helpline number : 011 - 61101010 Our contact center timings are : 9am to 5.30pm, Mon to Fri Our support id is: support@necindia.in
Posted on Jul 13, 2011
I think the lamp life has expired on old lamp. i have replaced the lamp but cannot get the projector to switch on. the amber power light is indicated and also the red lamp light. what should i do?
www.necvisualsystems.com/documents/.../vt460_560_660usermanual.pdf
www.support.nec-display.com/...service/.../manual/.../vt660_important_info.pdf
Above are your manuals for use and repair.
Sometimes there is a resettable thermal fuse near the lamp, this may have to be reset before it will go again. Sometimes there is a "Counter" to be reset too, but not always.
Aug 04, 2010 | NEC VT460 Multimedia Projector
Panasonic projector Pt-LB60u has a greenish hue around part of the edge of the projection. What would be causing this?
upon the bulb life running out on pani projectors and proj. tv's the lamp set will start to produce a green hue get a new lamp bro. try this web site i highly recomend them www.electrified.com
Feb 08, 2010 | Panasonic PT-LB60U Multimedia Projector
NEC Multisync MT1000 Projector - Green Hue
its not the bulb problem . the lcd block need sto be replaced , better to buy new projector
Feb 06, 2009 | NEC MultiSync MT1000 Multimedia Projector
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
Double display
Hi yaali
Try using a different cable.
If the problem however persists , then you will have to get the Mainboard either repaired or replaced.
May 17, 2008 | NEC VT460 Multimedia Projector
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Hello
Dec 16, 2007 | NEC VT460 Multimedia Projector
Whatever button i press the status light flashes and nothing happens?
hi 1) Check that the power cable is plugged in and that the power button on the projector cabinet or the remote control is on. See pages E-16 and 17 in the manual http://www.fixya.com/user-guide/p155892,m5221,gm34/NEC-VT460-Multimedia-Projector.aspx 2) Ensure that the lamp cover or lamp housing is installed correctly. See page E-30. 3) Check to see if the projector has overheated or the lamp has reached the end of its usable life. If there is insufficient ventilation around the projector or if the room where you?re presenting is particularly warm, move the projector to a cooler location 4) You have pressed control panel key when Control Key Lock is enabled good luck
Apr 20, 2006 | NEC VT460 Multimedia Projector
NEC VT460 Multimedia Projector Logo
132 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
