Question about Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard
Repeated boot. My pc was packed away for 4 months in its original box. I took it out and connected all the enitial cables. then i powered it on. a weirde sound came from the case. goin like this (WwWwWwWwWw) where it should be more like (WWWWWWWWWW. I looked at the motherboard LED chip, all the codes where standered boot up. CO,23,46..... But after about the first 5 boot codes, it goes --. then it startes again, it just repeats boot up, no BIOS, no nothing, all cabvles connected correctly. Pc on 8 mounths minus 4 old. so 4 mounths. It has Water cooling. whan i looked at the disc-drives, it kept on blinking every 2 seconds, i could not open ethier of them, please help. Sunite
    Scholar:
  • 113 Answers
Ok... first check that all power cables from your supply are firmly in place and that the little red or green switch on the back of the computer that changes the Voltage setting is correct unless you have a UPS. secondly make sure no loose debry, cable, or cpu box it touching the motherboard and it is still secure in its mountings. then check that the power, reset and all LED plugs are correctly connected to your MB for connections look at your user book for details. now how far does the computer go in the POST ? if its possible i would also reset the BIOS by either removing the battery from the motherboard and starting it up then replacing it and downloading system BIOS chipset boot disk from: http://driverscollection.com/?V=Foxconn&S=4 good luck.
Posted on Sep 22, 2007
6ya staff
SOURCE:
My older HP P07456 DVD drive came with a USB cable that cannot connect to my newer HP Elitebook PC. It has a separate power pin. Can I buy a different adapter cable to use it?
came with, you bought this DRIVE new? or found it
I added Came and USB to your post
now we know its not the lost power cable and is in fact the lost USB cable out of the original box from hp.
what is your story there,?
and external HDD, it is right? no , DVD special DRIVE,
it has 2 cables (data and power)
it came new with a power pack and 2 cables
new in the box.
1 with your funny uSB +1 pin for tc4200 pen tablets
2 usb for normal PC you lost.
1 power pack. 5v 3amps
RTM yet, the manual, lost that too?
Oops a hard manual to find this old.
read huffers post here. at omg real HP.com is this clear?
https://h30434.www3.hp.com/t5/Notebook-Hardware-and-Upgrade-Questions/HP-Ext-dvd-drive-EXT-MB-CRADLE-P07456-CNU402170K-4K0412-Rev/td-p/270630
that extra pin below is for only old tc4200 pen tablets
not for your PC, so if the normal, A-B cable is missing
the buy that.
the bottom is clearly marked, 5vdc 3.0amps, 15 watts or more.
it uses some very strange custom foxconn usb cable.
if it has power adaptor working and plugged in.
the std AB USB cable works.
at walfart cheap
https://www.walmart.com/ip/Tripplite-U022-010-Usb-2-0-Certified-A-b-Device-Cable-u022010/41099935
Jan 31, 2018 | HP Computers & Internet
2005 Mercedes Benz C230 Kompressor - Mileage: 110,000+ Experiencing repeated failures with replacement Ignition Coil Packs - failures have occurred at Cylinders 1, 3 and 4. Cylinder 2 still carries...
Try leaving the dress up cover over the coil packs off. It may be engine heat. Also check alternator voltage is not over 14.6 volt when engine running at fast idle. You are not alone with this problem.
Oct 20, 2013 | Mercedes-Benz C230 Cars & Trucks
Monitor will not boot up is reading no input signal
So either the computer isn't generating a video signal, the cable isn't carrying the signal to the monitor, or else the monitor isn't capable of receiving a video signal.To test this, first try a video cable that you know is good, in case your cable is bad, If it works with the other cable, the problem was your original video cable. If it still doesn't work, put your original cable back, and hook another computer up to the monitor. If the monitor makes the same message, the problem is with the monitor. If the other computer works when connected to this monitor, your problem was that the original computer isn't booting (which could be due to several reasons I will list below), or the video adapter is broken.Possible reasons for the computer not booting: bad power supply, bad power button, bad hard drive, bad memory, bad motherboard component. If you determine that it isn't booting, unplug everything except the keyboard mouse monitor and power cord, to see if that makes a difference. If it boots after that, something you unplugged was causing the problem, plug them each back in one by one, rebooting in between, and when it stops booting properly, the last thing you plugged in is causing the problem.
Mar 02, 2012 | Acer Computers & Internet
Drum Error - Clean Corona Wire msg won't go away
It started to say that Drum Error - Clean Corona Wire. So I took it out and cleaned it like it said, put it back in, same error...repeated this 3 or 4 times. Looked online and it said to try cleaning metal contacts so I did...still doesn't work.not connected to a computer.
Jul 19, 2010 | Brother DCP-7040 Laser Printer
We have a 11 month old elite traveler scooter. The battery will not take a charge. We have had no previous problems. Any suggestions?
I just fixed this problem in a Go Go Elite that was less than 6 months old. We would plug in the charger and the "charge" light would not turn on, just the "power light" I took out the battery pack (check manual for instructions), removed the cover (8 philips head screws) and checked the voltage on the two batteries. One read 4.5 volts and the other 4.7 volts. They should both read at least 11 volts, ideally 12 volts. Evidently the Pride charger will not work if it detects that the batteries are too low. So I took out one battery at a time and connected a 12 volt auto trickle charger to it for 3 hours on each battery. Checked voltages and it brought them back up to 11.5 volts. I reinstalled the battery pack and then connected the Pride charger and THEN it showed a "Charge" light. I left the pride charger on for 12 hours and it brought it up to full charge.
Advice: Don't let your batteries get too low or the factory charger will not work.
May 19, 2010 | Pride Mobility Products Go-Go Elite...
Dell vostro 200 4 repeated beeps on start up
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 05, 2009 | Dell Vostro 200 PC Desktop
Acer Aspire 5315 won't boot, black screen
I had the same symptoms on friends laptop. She had nothing to lose so gave me carte blanc.
Took out battery (to eliminate as problem) plugged in power, and powered up
Power light OK, HD flashed, CD flashed, then black screen. Powered down.
Did the following:
1) took cover off of fan/circuit board (see http://www.insidemylaptop.com/ for details). (4 screws)
2) take out fan (3 screws) and find huge amount of gunk on cooling fins at fan disch. Blew out with compressed air. Also cleaned fan blades.(reboot shows didn't fix.)
3) Repeated step 2, Pulled out memory sticks and cleaned terminals by rubbing with lint free cloth. Replaced memory sticks.
4) System boots normally. Replaced battery. Boots normally.
DAMN I'M GOOD!
Jan 05, 2009 | Dell Latitude D600 Notebook
Hard Drive not found after installing software.
  1. Boot to the bios with the HDD connected
  2. Turn on all the lock lights on keyboard (SCROLL< CAPS<NUM)
  3. Press ALT+E (Wait for Beep)
  4. Press ALT+F (Wait for Beep)
  5. Press ALT+B to reboot
  6. IDE redetect should initialize on boot.
  7. HDDs should now be seen
Sep 29, 2008 | Computers & Internet
My Acer keeps loosing power
hmm...sounds like you are suffering from a dirty power issue. how old is your house?
Mar 11, 2008 | Acer TravelMate 2300 Notebook
Xbox component output causes "epileptic" flickering
x box 1 on a hdtv r u sure , or do u mean the 360?
Sep 13, 2007 | Microsoft Xbox Console
Foxconn C51XEM2AA-8EKRS2H (0683562100229) Motherboard Logo
144 people viewed this question
Top Foxconn Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
