Question about Nokia 3600 slide Cellular Phone
I have no incoming call id
I have a nokia 3600 slide & when i have an incoming call the number doesn't appear on the screen or the names stored in my phonebook. all it says is "call". in short i have no incoming call id so never know who's calling? can anyone help?
Selected video format are played.
Posted on Aug 22, 2009
HI,
Mostly likely your incoming call id is not active. Please call your service provider and tell them to activate this feature.
I had the same problem on mine. It is now fixed.
Hope this helps.
Posted on Aug 07, 2009
UNlock nokia phone model3600 slide?
Hi, You can unlock a Nokia 3600 SLIDE safer and easier using unlock code. You can get the unlock code for a Nokia 3600 Slide from www.unlock-zone.com/nokia-3600-slide/rs16wp9/ at low cost.
UNLOCKING STEPS FOR A NOKIA 3600 SLIDE
1 - Switch on your Nokia 3600 SLIDE without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3600 SLIDE.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3600 SLIDE would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3600 SLIDE mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3600 SLIDE
Oct 18, 2012 | Nokia 3600 slide Cellular Phone
My new Hp Officejet j3680 caller ID is not working... All the phones in the house display the incoming phone numbers except the j3680. I wonder why?!! it shows instead ringing!!!
The caller ID phone having the tip & ring detection circuit to detect the incoming phone number, but in this model doesn't have tip & ring detection circuit to display other phone number but after connecting the other fax it will read the information which was stored like company name & phone number of other one..
Jan 04, 2012 | HP J3680 Officejet All In One Printer
Locage Code de restriction nokia 3600 slide imie 359306/02/513989/8
Each Nokia 3600 SLIDE mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3600 SLIDE mobile phone at www.mobileunlocksolutions.com.
Jan 31, 2011 | Nokia 3600 slide Cellular Phone
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Incoming phone number displays but not the name in
Some nokia set has this kind of problem as we dont store the names with '+91' . This problem can be solved if the no is saved with '+91'.
thanks,
saumya.
Aug 04, 2009 | Nokia E63 Cell Phone
Nokia E66 Incoming name or number of callers not
It's because the caller using voip (ie Skype or similar with hidden id)
Jun 04, 2009 | Nokia E66 Smartphone
How get do I get my incoming phone numbers to be displayed
Most phones will only do what you require if the contacts are stored on the phones memory instead of the SIM memory. This will also prevent you from assigning photos to contacts and one touch speed dials (i.e. press and hold a number to dial a stored number) Try copying all your contacts to the phones memory. If you see duplicate names, go into phone book settings and adjust setting for phone just to look at phones memory and this will stop duplicates being shown. hope that helps?
Apr 26, 2009 | Nokia 6600 slide Cellular Phone
Caller id
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Oct 13, 2008 | Panasonic KX-TG5672 Twin Cordless Phone
Nokia 3600 slide Cellular Phone Logo
203 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
