Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
I have a ryobi weed eater and the twine locks up and wont release
I have carefully wrapped the twine around the spool and after a couple of bumps for release, the twine locks up (tightens) around itself inside the spool housing and then will not release. I have gone to smaller twine thinking that might help but it does not. I even replaced the twine spool thinking that was the problem, but it is still doing it. I must be doing something wrong.
    President:
  • 1,489 Answers
There is really no solution to this problem -- it is inherent in weed **** -- I have extensive experience with this phenomenon, spending many hours trying dozens of approaches. If you need a **** my suggestion would be buy a new one -- it'll get you through a season or two...
Posted on Apr 21, 2009
How can I remove the cartridge head to clean?
Usually the cutting head will have a couple of plastic tabs you push in to release the spool cover and get access to the spool
Mar 06, 2016 | Garden
Ryobi weed eater troubleshooting
Here is a video I found helpful.
https://www.youtube.com/watch?v=iMFUW6DJia0
Aug 19, 2014 | Garden
I have an electric RYOBI weed eater and I need HELP...manual/instructions on how to access the spool so I can feed the line through the exit hole and use the thing! Thank you. Have two numbers: EL...
Unscrew thw bump nut to remove the spool. Take a length of about 6 foot of line, kink it in the middle and pass this through the hole in the spool. Wind the two lengths of line around the spool in their own divisions and in the same direction. The direction of wind is embossed in the reel and the line should be wound tightly and held all the while. When you have about 6-8 inches left in your hand, bring the cover up to the spool and carefully pass the two ends of the line through the holes, push the cover all the way over while pulling on the two pieces of line and ensuring that the lines stay on their own side of the division on the spool. Fit and tighten the bump nut and trim the lines to just about the cut-off blade.
The lines should trail out of the holes in the direction of the machine's rotation. Try cut with the tip of the line as much as possible. Cutting nearer the drum flexes the line and will lead to early breaking of the lines. Run the motor at a constant speed and rather move the cutting head in and out of the weeds to affect a deeper cut
Jul 09, 2011 | Ryobi 15" Electric Factory Reconditioned...
Line installation
Hi bluemontel52...
Hi
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Poulan Weed Eater Rte115 4.5 Amp Electric...
How to replace string on te475y
Hi jtl91370...
Try this solution...
Jul 02, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
I need to replace wire on an electric weed eater auto feed 15 inch
Hi deanko1
Jul 01, 2011 | Homelite Garden
I like to know how to wier the line om my poulantrimmer model ppo25\
Hi rlgingas...
Some you will have to remove the center knob.
Jul 01, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I just bought a craftsman weed eater and the fishing line gets caught up and wrapped around the spoke of the turning mechanism in between the the covered spool and the machine. How can this be fixed. Is...
it is very hard to rewrap the line in any weed eater. Techs get paid good money to do this, and there is a spring that must be placed inside the spool container that gets pressed to release new line. My suggestion, if is giving you this much trouble, and, will every time it needs new line. remove your old spool and go to the hardware store and purchase a spool that has plastic or metal blades on it. ie, no line, nothing to wrap, nothing to feed. Just be careful using it and do not let a child near it, it will nick you. They are less than 20 bucks and alot cheaper than getting a technician every time it needs to be rewound. I worked for sears and we saw these every day. If you must have the line. follow the steps in the manual step by step, it does take some force to get the spool back on properly, because of the spring. just make sure you direct the recoil away from you or your body at all times.
Jun 11, 2009 | Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
360 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
