Question about Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom Lens
AF-S Nikkor 17-55mm DX 2.8 G Lens overexposing images on D300
The D300 internal meter is reading incorrectly for this lens when mounted  and all images are wildly overexposed. Tried another lens and it is working fine w. D300 + internal meter so it is the lens for sure.  Autofocus is in the lens working but in order to expose correctly have to push the meter up to 1000's of a second. Is this something to do with the contacts or rubber ring letting in additional light? Is this a common problem?
SOURCE: Nikon D50 autofocus
I just encountered the same problem. The advice giver who forced the focus ring with autofocus engaged was right on the mark. (Thanks!) Actually, I didn't need to force it, just gave it a firm push. Voila!
Posted on May 03, 2007
SOURCE: Nikon D80 Autofocus problem
Try re-setting the camera? On the D40 it is 'Menu' scroll down one to Custom Setting Menu (a pencil) and click reset 'ok' yes 'ok' this worked for me.
Posted on Sep 09, 2008
SOURCE: Camera won't autofocus
I too had D50 autofocus problems and ended up buying a new D300. I then learned that my issue was in the focus areas. The D50 has five focus areas. As you look through the lens, you will see one rectangle in the center and four to the top, bottom, left and right. You should make sure that the center rectangle is highlighted. Use the round thumbdial on the back of the camera to move the focus area.
Posted on Oct 31, 2008
  • 6 Answers
SOURCE: Nikkor 50 1.8 overexposes
You probably have oils on the aperture blades and they do not close to the F stop you set as quickly as required, thus causing the over exposure. Easy to pinpoint: sent the aperture to full open (F1.8) and use appropriate shutter speeds as determined by the camera (in manual mode), if the picture does not over expose, then the problem is with the oiled contaminated aperture blades. Have it cleaned.
Posted on Feb 15, 2009
  • 4 Answers
SOURCE: nikkor 70-300 lens wont autofocus on d60.. HELP!!!
There is a known defect in some of the Nikkor lens' that were manufactured during a certain time period. The same thing happened to my lens.. it stopped autofocusing for no reason at all. (It was purchased in May 08). I shipped it to Nikon and I received a new lens within 10 days of shipment. You have a 3 year warranty on the camera and the lens'. Nikon has AMAZING customer support when it comes to legitimate issues.
Go to the web site. Fill out a repair order and send the lens to them exactly as stated in the instructions. You will have a new lens within 2 weeks.
Posted on May 25, 2009
Does anyone knows how a Vivitar 75-260mm lens will works on nikon d3000?
Vivitar makes lenses with a variety of mounts. Assuming the lens in question has a Nikon mount then it will fit perfectly well on a D3000. If the lens has a Canon mount, for example, then it will not fit at all.The lens is a manual focus lens, so autofocus will not work. You'll have to focus by yourself.The lens also lacks the electronics to communicate with the camera. You will have to shoot in the Manual exposure mode, setting the shutter speed and aperture yourself, without any help from the camera's light meter.
Apr 11, 2012 | Nikon D300 Digital Camera
Did the sigma 75-300 dl will work with nikon d300?...i mean the auto focus and matrix focus
Yes. The D300 has a focus motor built into the body and thus does not need one in the lens. The lens will also meter properly with the D300.
Aug 10, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Sometimes photos are overexposed using A or P mode on my Nikon D80 with 18-200 mm lens. I remove the lens, then re-attach it and all is fine. What is happening? Poor contacts?
Contacts should not have anything to do with the metering. That is done in the camera itself and not the lens. If a photo comes out overexposed, which is normal when using P or A mode, as metering isn't perfect, use the exposure compensation (+/- menu or button) to reduce the exposure as much as you feel is necessary. Exposure can be subjective so you should trust yourself more than the camera.
Jul 20, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
I do have old Nikon lens manual 1.2/50 mm,want to use it with modern digital SLR-which one can be used with,where I can get converter?
No converter needed. The lens will fit on every Nikon dSLR ever made. However, there are two things to keep in mind. One, most dSLRs have a sensor smaller than a frame of 35mm film. Thus, the camera only captures the central portion of the image, effectively giving you the same field of view as a 75mm lens instead of a 50mm lens. This applies to every camera except the D700 and the D3 family.
Two, this lens will shut off the meter on most dSLRs. You'll need the D700, D300 family, or the D3 family to be able to use the camera meter with this lens.
Feb 17, 2010 | Cameras
I've got nikon D300, & 18 ~ 135 Nikkor lens for wild life & potraite photography I'm confusing to go Between 70-300 or 100-400 range anyone pls suggest....
The 70-300 is less expensive and lighter. The 100-400 has a longer reach. Only you can decide which factors are the most important to you.
Aug 31, 2009 | Nikon VR Zoom 80-400mm f/4.5-5.6D ED Lens
Nikon D300 When I depress the shutter half way or fully on my D300 the frame counter reads r27 and the lens (any previously compatible Nikkor lens) will not auto focus. The camera is not set in burst mode...
Only reason the lens will not auto focus when you depress the shutter half way is due to either lens AF switch is set to Manual OR camera body's focus system is on M. There is 3 way toggle switch below the synch port around the lens mount. It should be set to C or S in order for auto focus to work. If all the settings are correct and even "AF-ON", next to rear dial doesn't activate auto focus then the issue maybe in the setting or the body itself. As for the buffer reading r27, I think mine displays r## regardless of burst/continuous mode.
Jul 13, 2009 | Nikon D300 Body Only Digital Camera
D300, SB-800 fires but no exposure.
Thats is odd.
When you hook everything up, do you turn on the flash last?
It sounds like the battery pack is giving the flash a different voltage then it should have causing incorrect readings and exposures.
I would send the pack back to Quantum(located in Ronkonkoma, NY) and have them check it.
Jul 13, 2009 | Nikon Speedlight SB-800 TTL Flash
Sony CyberShot DSC-T33 has stopped working
Its CCD Imager problem in your DSC-T3 camera and Sony offers free of cost repair for same problem.
Click Sony CCD Imager Support for details.
Jun 04, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Blank on the Display after Shooting
Dyel,
Sounds like you tried a lot of the suggestions I'd offer, try to hold the reset for longer than 2 seconds for the reset. It's a wild shot but did the lens get chaged with the camera on? That is a definite no-no. Can cause damage. If it's only a couple of months old and resetting dosen't work ship it back to Nikon for evaluation service.
randy320sgi
Nov 03, 2008 | Nikon D300 Body Only Digital Camera
Nikkor 105mm Ai-S micro lens aperture seems stuck
It does sound like your lens diaphragm/aperture ring coupling mechanism is in need of repair.
May 03, 2008 | Cameras
Nikon 17-55mm f/2.8G ED-IF AF-S DX Zoom Lens Logo
56 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
