Question about Panasonic KX-MB781 All-In-One Laser Printer
Drum reset for Panasonic kx-mb781
1. My display said I was going ot need to replace my drum and then it stopped and the display said to replace it.
2. I then removed the old drum and reinserted the old drum back and nothing changed.
3. I then replaced the od drum with the new drum and everything worked fine.
4. Just for kicks, I then replaced the old drum and the old drum now works fine.
5. I conclude that the new drum reset the machine's counter.
IS THERE A WAY TO MANUALLY RESET THE COUNTER?
  • 3 Answers
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 03, 2009
  • wawan609 Oct 23, 2010
    I used that trick for my MFP KX-MB2010CX. It worked too. Thanks guys
    Sergeant:
  • 284 Answers
There is no way to reset the counter manually and by not using your new drum, you might have just lost it when it says replace drum again
Posted on Apr 22, 2009
  • Newbluebox Jan 31, 2011
    Yes, It's worked too. Thanks
While waiting for the new drum to arrive from Amazon, I need to print an urgent document. Once I followed HobbesVT's suggestion and turned the white gear counterclock-wise, the printer print a beautiful page and no more "replace the drum" error message. Not sure how long will this last, but definitely worked in a bind.
Posted on Apr 13, 2015
I need to reset the drum supply how do i go about it
On this specific unit, the drum actually has a small resister on the back of the drum unit that resets the machine when a new drum unit is installed. Your options are either to replace the drum unit with a new one or find the exact resistor from your local electronics store and replace it ( not recommended as the drum life is already reached) there is nowhere a menu that lets you reset the drum. Hope that helps
Oct 28, 2013 | Panasonic KX-MC6020 All-In-One Laser...
Drum life over in panasonic kx-mb1500
how reset panasonic kx-mb1500 drum life over
Jan 11, 2013 | Panasonic KX-MB781 All-In-One Laser...
Drum life over replace drum
reset drum code
menu # 9000 * 672 2 start
Nov 03, 2010 | Panasonic KX-FL611 Plain Paper Laser Fax
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
How can I reset Replace Drum on the Panasonic KX-FL511 Fax?
First of you will have to purcahse a Panasonic Drum Unit for you fax.
Inside the drum unit yu will have detailed instructions, you will open up the fax in the front take aout the old and install the new.
Here is a link to a helpful guild
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/How-To-Guides/model.KX-FL511.H#ts
Good luck
Nov 05, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Panasonic KX-MB781 drum reset
I already answered this at some other place her - but here I go again: There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Apr 20, 2009 | Panasonic KX-MB781 All-In-One Laser...
Reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Jan 07, 2009 | Panasonic KX-FLB801 All-In-One Laser...
DRUM REPLACEMENT CODE
How to Reset the “Replace Drum Cartridge Soon” Message on a Panasonic KX-FL511
[Menu]
[9000]
[*] (Will display P-SF)
[6722]
[Fax Start]
[Menu]
Nov 18, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-MB781 All-In-One Laser Printer Logo
3,089 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
