Question about Toshiba 13A21 13" TV
My Emachine D520 Hum Any Time I Plug It Into My Dj Setup Through An Out Board Sound Card Via USB Hub
When i plug Numark DJ/iO Sound Card in pop up message says "USB Device Not Recognized - One of the USB devices attached to this computer has malfunctioned, and Windows does not recognize it. For...
there are drivers needed for this item you may need to download them also re install your usb drivers an attach to a different usb port not thru a hub.
Mar 15, 2011 | Numark DJ/iO Sound Card
I don't know how to get sound on my emachine d520
try reinstalling the sound driver if that doesnt work plug your speakers into the headphone jack http://support.emachines.com/em/driver/nb/d520.html
Jan 03, 2010 | Audio Players & Recorders
How difficult is it to put in a new USB root hub in an EMachine W3622
Quite easy buy one from fry's online a 4 port pci slot type and remove the two screws on one side pull the safety plate off the PCI slot off the case and install the PCI card into the mother board and install screw and run the DVD to make the usb ports work and pt lid back on and your set to go.
Jun 19, 2009 | Logitech QuickCam Express 5-Pack Personal...
Installation problems with HP dj 460c drivers
unplug the printer then install the drivers then reboot the PC then plug in the USB printer to USB port then insert again the CD installer..if their is same the problem you need to re-install the OS/windows...good luck
May 27, 2009 | HP Deskjet 460c InkJet Printer
Emachine T1220 with only one restore cd...what else can I do?
1 Solution for "When ever i plug my eMachine into my dj system through a usb sound card it hum
Apr 17, 2009 | E-Machines eMachines Desktop PC
All of a sudden my Echo Indigo DJ soundcard will play both virtual CD players on my PCDJ software on one channel. For a while, I had cd 1 on one channel and cd2 on the other. I am using a pig tail plug...
I can run audio on 3 separate channels/outputs of my laptop
I use Tricerasoft Swift Elite DJ software but the areas you need to look at for troubleshooting are probably similar:
1) check the (PCDJ) software settings for selecting the channel outputs of your Indigo DJ on each deck/ player. NOTE: 1/2 and 5/6 are the same physical port (headphone port), while 3/4 and 7/8 are also shared on the Line Out port. So make sure you use for eg. one player uses 1/2, and the other player uses 3/4 ONLY IF you want them running out to separate channels on the mixer
I personally run both my decks off the same channel, ie 3/4 so that my software can do the mixing for me. My mixer only acts as an master control device where everything else connects
2) Make sure you check your IndigoDJ Console (installed to the Windows Start menu under Echo Audio, Indigo DJ), if you have any conflicts or if for some reason one particular channel pair gets inadvertently muted, resulting in no sound coming from the port.
3) I also use my onboad sound card (typically for previewing music or for an auxillary output). This is obviously controlled by the Operating system... in Windows is is through the Sound properties, default sound device. I recommend NOT using Indigo DJ as a default sound card -- but that is a personal preference.
So in this way you actually have 3 outputs for sound
As far as cabling is concerned, it depends on what you are connecting to. I use a 1/8 (mini computer) jack to 1/4 whcih then plugs into a direct box (eleminates any static hum etc), then from the DI box using an XLR cable to the mixer. Your setup may be slightly different.
Hope this helps!
Dec 01, 2008 | Echo Indigo DJ Sound Card
Mercury MOTHERBOARD KOB P4M266 NDFSMX
I AM NOT HAVING MOTHER BOARD CD TO INSTALL HIS DREVERS AND HOW TO DOWNLOAD HIS DRVIERS BY INTERNET
Mar 04, 2008 | Mercury KVM266PM-U (KVM266PMUD1600)...
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
Toshiba 13A21 13" TV Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
