Question about Kyosho Toys
Directions to install decals on the fairwind 900 kyosho sailboat
I need directions to install decals on the Fairwind 900 kyosho radio controlled sailboat
Why does my syncro KT-200 have random unresponsive times?
try turning both receiver and transmitter to G and not F. G is for Great Britain and has a better range .... rather than F that is for France
Apr 13, 2014 | Kyosho Syncro KT-201 2.4GHz Pistol Grip...
Rear wipers on 2008 inpreza not working
Could be wiper motor but first check the fuse . Your manual will tell you which # fuse controls rear wiper
Jan 04, 2014 | DRx Subaru Impreza WRC Ready Set with...
FACTORY MANUAL
http://www.kyosho.com/jpn/support/instructionmanual/digital_prcs/pdf/82119_Syncro_KT201_IM.pdf
Sep 19, 2013 | Kyosho Syncro KT-201 2.4GHz Pistol Grip...
I need a Radio Flyer 90 decal
decals can be found at bluediamondclassics.com, also from radio Flier in Chicago IL. all their products lifetime warrenties
Apr 14, 2012 | Toys
Need a manual for dash 8 kyosho 750 side car and can you tell me the size of this car engine Thanks Albert
How can i get a copy of Kyosho sidecar 750 Dash 8 ?
Thanks
Albert
Email:albertlo338@yahoo.com
Mar 20, 2010 | Kyosho Toys
How to install a U8172-900 belt
your savvy bagless has a geared belt. remove the bottom plate and then remove the 2 back screws near the back wheels to remove the top cover also peel off the hoover decal to access the top cover screw. this will expose all components to replace the belt.
Sep 28, 2009 | Hoover U6630-900 WindTunnel Bagless...
My antenna broke, i purchased new antenna but when I tried to install new antenna the old antenna fell inside of radiio, I took out all the screws but still cannot get radio apart
On the back panel, there is a black decal located near the center. Warm this decal with a hair dryer (warm it, don't get it hot)Slip a knife blade under the right side and lift it up. Remove the hidden screw under the decal, and the the other five and the back will come off. replace the FM antenna and you are good to go. I had the same problem. mcarmich
Jun 13, 2009 | Eton FR300 AM/FM/Weather/TV Radio
'88 Saab 900S T convertible Radio removal
you need to get the adaptor for the harness at circuit city or radio shack or any audio installer shop
Sep 20, 2008 | 1988 Saab 900
Toys Logo
108 people viewed this question
Top Kyosho Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Kyosho Toy Expert? Answer questions, earn points and help others
