Question about HP Compaq Presario V5204nr Notebook
Screen black I have a Compaq Presario v5204NR Notebook PC. It boots up and there is sound, but the screen is completely black. If I shine a flashlight on the screen the normal desktop is there as usual in the background. Help please.--Chris
  • 2 more comments
  • Chris Steer Apr 19, 2009
    Thank you very much. I have tried the FN + F8 to increase brightness to no effect. Can you tell me how to find the inverter--what it looks like? Is it easy to pull out? Thanks so much.--Chris
  • Thomas Marengi
    Thomas Marengi Apr 19, 2009
    The Compaq Presario V5204 NR screen is completely black. No image at all, but sound works fine. The unit looks impossible to take apart to determine if all internal cable connections are secure. Any suggestions short of sending this back to HP for a gouging?
  • Chris Steer Apr 20, 2009
    Thank you very much Joe! I will try to fix it via your links and let you know what happens. Regards, Chris
  • JDTec
    JDTec May 11, 2010
    Sounds like your Inverter, which controls the contrast and brightness, is bad. The inverter is inexpensive and usually easy to replace.
Dear forevencris,
I was able to fix the problem with the "black screen". I took apart the machine which is quite tenuous to get at the cables attached from the mother board to the screen itself. One of the ground cables was crimped and I repaired with a re-solder. Also, the main display cable was not seated properly. After reseating and re-assembling, all works well.
If you are good with a screw driver and small screws, you can do this. Be REAL CAREFUL not to damage any of the electronic or mechanical components with an errant screw driver. Be real patient and plan on at least an hour to perform this surgery.
Contact me for assistance should you desire. Good luck.
Best Regards,
Tom
Posted on Apr 20, 2009
  • HP Master
  • 4,338 Answers
I buy them from Smartmicro, very reliable and good prices:
http://www.smartmicrousa.com/hp_compaq_inverter_board.aspx?page=2
I could not find your model's manual, but this show how to replace it on a Compaq V2000 which should be similar and should give you a good starting point.
http://www.screentekinc.com/lcd-removal-instructions_en,IBM.shtml
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 19, 2009
The screen on my compaq presario cq56 is black
The problem is caused by the inverter board, "just below the screen" is more than likely the problem, or it is the backlight behind the LCD display, "built in" less likely.
Apr 23, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
While using my compaq cq61-412nr notebook my scree will suddenly go blank when i open and close the lid a coulple times it returns then blackouts again
It sounds like you have a bad LCD DC inverter board. This device low voltage DC current into high voltage AC current, which is required to power your LCD screen's back light. Here is a simple test to determine whether your DC inverter board is bad:
1. Power on your computer 2. If the screen initially turns on, either wait for it to go black, or perform any action that you know consistently makes it go black. 3. Find a standard flashlight and shine it directly at the screen. If you can see your display with the light shining on it, then your inverter board needs replacing. You may need to maneuver the flashlight to a particular angle to see the display through the glare of the flashlight on the screen.
Replacing the DC inverter board is inexpensive, if you are moderately experienced with the mechanical aspects of laptop computers. The replacement part will run you between $20 and $40 (here is one that fits your computer for approximately $20: http://www.zlectronic.com/product/For-Compaq-presario--cq61-412nr-Laptop-Lcd-Inverter-Display-Replacement.html). You should not attempt to replace the component yourself unless you feel confident about what you are doing. If you feel better having an expert perform the job, consult different computer repair shops in your area for a price quote on the labor. Be sure to let them know you will be supplying the part yourself; if you have them obtain it, you will almost assuredly be charged a mark-up.
If you found this solution helpful, please leave a positive rating!
Jul 18, 2011 | Compaq Presario CQ60-204NR Notebook
In my computer, i have Realtek High definition Audio Devive installed but i cannot get the suitable driver to activate it. My system is Windows 7 in Compaq Presario V5204NR Notebook PC.
Have you checked this page : http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=3197922.
I dont think your laptop have support drivers for windows 7. Try luck with these drivers.
Apr 19, 2010 | HP Compaq Presario V5204nr Notebook
My monitor is black, but when i shine a flashlight on it i can see my desktop
You might having trouble with the connection on backlight, or inverter side is defective or the backlight is actually give up.
Sep 14, 2009 | HP Compaq Presario V2000 Notebook
How to upgrade the cpu in my compaq presario v5000 with v5204nr motherboard and celeron 1.46gb??
Go to Compaq's website (Now HP) and find info (KIP) on the max Ghz it will support and what has to be done (maybe nothing, maybe switches or jumpers) set it and "POP" in the new chip!
GL!
Aug 24, 2009 | HP Compaq Presario V5204nr Notebook
My compaq preasrio r3000 black screen cant conect to an external
have you any other A/V ports out ie Svid etc if so try that via an A/V lead, if that works reset your bios settings to minimal settings, if that doesnt work search the 'net someone somewhere has had the same problem! try shining a flashlight/lamp onto the screen whilst booting up, if you see anything on the screen then your inverter is definatly gone and yes it could still be your inverter! your laptop may have software/hardware issues with an external monitor?
Mar 09, 2009 | Compaq Presario R3000 Notebook
HP Compaq Presario V5204nr Notebook Logo
163 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
