Question about Garmin nuvi 260W GPS Receiver
I just bought the Garmin 260w GPS. This unit is cool except the supplied car charger doesn't work in my '07 Camry. Does anyone see the same problem? In the manual is does mention something like, replace the "fuse" of the vehicle charger with a "1A fast blow fuse". Did anyone tried that? Any more details would be appreciated.
  • 121 Answers
Check the voltage
Posted on May 05, 2009
My nuvi 260W displays the computer plug in sybole then turns of both while move and sitting still an d is connected to power supply. I have bought new connector for power supply.
Whenever you see the computer to GPS symbol pop up while using the DC car charger, this is an indication of a loose USB jack (bad connection) between the jack and the printed circuit board.
You should only see this symbol when connected to the PC using the USB cable. You should never see it when using the charger. Please see this link for more information and how to have it repaired:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Apr 09, 2014 | Garmin nuvi 260W GPS Receiver
When i charge my garmin nuvi 260W with a car chager, the screen would be stuck, and i'm not able to use it.?
garmin are very fussy about there chargers if its the original charger then there is a fault with it if its not the original then get one ( you can only use genuine garmin chargers for garmin gps units) they have a clever sensor in them that stops you from using any other type of charger
Jun 28, 2010 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w is not charging with car charger
You have a short in the wire that runs to your unit. Other than holding the wire in the exact location until your charge is complete you would be better off replacing the charging cord. They should be available at your local shop for around $19-$29.00.
May 29, 2010 | Garmin nuvi 260W GPS Receiver
Nuvi car charger problem
the connector is defective in the GPS, this is a common problem, it must go back to Garmin dfor repair
May 28, 2010 | Garmin nuvi 260W GPS Receiver
No power either from car charger or from computer
try plugging it into a computer via usb cable and see if that does anything. if not then your unit may be fried and have to be sent into garmin for repairs or returned where you bought it.
Aug 12, 2009 | Garmin n?vi 260W GPS
I would like to register my Garmin NUVI 260W How do I register mygarmin 260w? I cannot locate the screen to register my garmin. bettison@peoplepc.com Ser #1gs558646
You can register your GPS on www.myGarmin.com if it's a brand new unit. If someone else have registred it first (i.e. bought on eBay or similar), it could be a bit of a hazzle however.
Jun 02, 2009 | Garmin n?vi 260W GPS
Proper charging advice for Nuvi 260w
Turn it off and Always unplug it when you're done with it.
That's assuming you have a live plug (stays on when car turned off)
Mar 16, 2009 | Garmin nuvi 260W GPS Receiver
I game my parents a garmin 260w with just the car charger.
I would only us the Garmin charger. Why take a chance. They are fairly cheap. Plus you need the car charger since that's where you use it most of the time. The batteries don't last all that long.
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Nuvi 260w no power.
Yes, you need to charge it. USE the charger that came with it for best results. Some off brand chargers will NOT work.
You plugged it into your car and nothing? Even if the batteries are bad it should still work. Is it the Garmin charger?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your unit will not charge in your vehicle, you may need to replace the fuse located in the tip of the vehicle power adapter.
  1. Unscrew and remove the silver or black, round end piece.
  1. Remove the fuse (glass and sliver cylinder) and replace with a new fuse.
  2. Ensure that the silver tip is placed in the end piece. Screw on the end piece.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260w not operating while plugged in
If you are trying to use your unit in the car via the USB port and not the supplied cable, it will not work. You must use the bracket that came with the unit or the specific charger that came with the unit. The pins in the Garmin USB charger only use two pins whereas a regular charge cable uses 4.
Aug 14, 2008 | Garmin nuvi 200W GPS Receiver
Garmin nuvi 260W GPS Receiver Logo
260 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
