Question about Black & Decker CCS818 Chain Saw
Oil leaking out of brand new Black and Decker cordless electric
We put the oil in, and as soon as it's resting the oil leaks out again. Should we just take it back to the shop or is this a common problem?
  • 313 Answers
SOURCE: Black and Decker service manual CMM 1000
check out black & decker website
Posted on May 29, 2008
  • 384 Answers
SOURCE: black and decker cd12c cordless drill Charger
I would guess 12 volts
Posted on Jun 12, 2009
  • 6 Answers
SOURCE: Black and decker cordless lawn mower CMM1200
i had the exact same problem and i went into the hand switch box (the box on the handle with the lever attached to it) and cut out the safety switch and then took the two wires that were on the safety switch and soldered them to two poles of a heavy duty toggle switch. That fixed the problem for that year but one year later i.e. now, theres another problem with the mower and i can't figure out what it is. I have broken this thing down to the smallest parts and still can't figure out what is wrong. Bottom line try to fix it with the switch solution but don't buy another one. BLACK AND DECKER SUCKS!!!!
Posted on Aug 06, 2009
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Posted on Aug 18, 2009
dontbother10
  • 2220 Answers
SOURCE: need the manual for lp-1000. need to add the oil
Please try this, if not successful post back (below)
Black & Decker
Go To “ServiceNet/” link
Bottom of center column “Need a Manual?” Enter model number, “YourModel” in window.
Posted on Apr 02, 2010
Hi my Black & Decker kettle leaks
Great you have created art
consider oil painting style of the 40s with lace lots of lace
i use them for critter food storage out back
Jan 04, 2015 | Black & Decker Kitchen Appliances - Others
What type of bar chain oil should I use
For spring/summer use, you can use Motomaster ("spring/summer") or Stihl "medium" chain oil. If you use in very cold winter condition, you need thinner oil, specifically made for it.
Feb 02, 2013 | Black and Decker USA BLACK & DECKER...
New Black and Decker, 18 volt, cordless drill. I can't tighen the bit
I oil mine up to help the jaws move . also check the screw at the base of the chuck inside its a standard head. shine flash lite where you put the bit it holders the Jacobs chuck to the shaft.
Jul 07, 2011 | Black & Decker & Cordless Drill
Blackanddecker typye 2 recip-saw handi saw cordless ,blade wont stay locked in while cutting keeps poping out worthless to use as soon as u put presure on it pops right out
There is a small ball inside the chuck that sometimes gets stuck on these quick release chucks. Check and see if it is still in there and if it is see if it is stuck. If it is just put a drop of oil on it and keep working it. It will loosen up and you will be back in operation.
Jan 30, 2011 | Black & Decker Cordless Handi Saw
Best rgrds, W/D
Aug 18, 2009 | Black & Decker Drills
Newer oil pan gaskets for Ford, not like original..leaking again
try warming up the engine a little then re-tightening the bolts,if that doesnt work,mark where its leaking and pull the pan back off and apply sealant to that area a little heavier than the rest of the gasket surface,dont use too much on a new gasket,just a really thin coat...USE "ULTRA BLUE" sealant,NOT blue or black RTV silicone,silicone wears out and it can leak after a while..Allow the ultra blue sealant to dry for about 30 minutes before re-assembling it,and clean off all oil from the gasket before applying the sealant,its ok to apply it to both sides of the gasket,and add a glob to all 4 corners where the gasket meets with rubber seals around the crankshaft,but put those globs on right before you put the pan back in place,the sealant has to be wet to squish in enough..i hope this helps
May 09, 2009 | 1999 Ford Explorer
Black&decker smartboil leaks
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit is leaking, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility.
While this doesn't actually solve your problem, I hope the information allows you to make an informed decision as to how to proceed from here. Please let me know if I can be of further assistance.
Dec 09, 2007 | Black & Decker JKC450 Cordless Electric...
Leaking Oil from the front
DONT BUY A NEW ONE THEY ARE EXPENSIVE ... THEY PUT OUT VERY LITTLE ACTUAL BTU'S OF HEAT ...IT WOULD BE DANGEROUS TO TRY AND BRAZE ANY LEAK POINTS AND THE OIL IS NOT CAR OIL AND NEEDS TO BE FILLED TO FACTORY SPECIFIED LEVELS. (THESE ARE NOT MEANT TO BE RE-FILLED OR DOES THE OIL USUALLY DIASAPATE). OIL HEATERS OF THIS TYPE USE PLENTY OF ELECTRICITY. I SUGGEST A "HIGH QUALITY, THICK CASED, WITH TILT SAFTY, ELECTRIC SPACE HETER WITH A FAN. THEY HEAT PROBLEM AREAS SAFE AND EFFECTIVELY.
Apr 26, 2007 | DeLonghi 9707 Oil Filled Radiator Heater
Black & Decker CCS818 Chain Saw Logo
275 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
