Question about Lands Phones
When "memory" key is pressed, nothing happens; dial tone only
When the "memory" key is pressed, nothing happens....There's only a dial tone....
  • 37 Answers
The memory is empty and needs you to reprogram
Posted on Apr 20, 2009
Why does vtech not have a speed dial? my son is
Programming Speed Dial Numbers
The handset must be OFF.
1. Press PROG. The IN USE LED will blink to indicate that you are in the programming mode.
2. Press the number of the memory location you wish to store the number in (0-9).
3. Using the dial pad, dial the number you want to store. The number can be up to 16 digits long. The number can be entered manually or by using REDIAL.
4. Press MEM to store the phone number
to the key you selected.
The phone now exits PROG mode and emits a tone.
Speed Number Dialing
1. Press PHONE to get a dial tone.
2. Press MEM and the memory location number key (0-9). For example, to dial the number you assigned to key '8', you would press PHONE, MEM, 8
May 27, 2011 | Vtech 9009111 Cordless Phone
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
Feb 13, 2010 | Nortel Meridian M7208 Corded Phone
Outgoing memory is full
press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to ALL JOB CLEAR
set
wait for a reboot, about 2 mins.
Your fax machine most likely is not finding a dial- tone, so faxes are piling up in memory and are never being transmitted.
After the reboot, press the monitor key once and listen for the dial-tone.
Jan 20, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Comdial Executech 6714x-PG We have nearly 20 phones. All of them get a dial tone but nothing happens when you press 9 to dial out, none of the phones will dial out. Calls can come in only. Thank you
they are either restricted or what you are hearing is intercom tone and not dial tone. the phones may be set to dial out from a diffrent line grop as well have you tried dialing 81 82 instead of 9 and see what happens
Jan 05, 2010 | Comdial 6714 14 Button Executech Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
