Question about Maytag MBF2256H Bottom Freezer Refrigerator
Maytag bottom freezer ice maker problem of ice removal
The ice maker in our bottom freezer has had a problem since new which is about 5 years, in that the last cube in the row will not eject properly. The rest of the cubes are ejected properly but the last one toward the rear sticks and the ice maker growls continually until I eject it manually. The dealer replaced it several times when it was in warranty but we both gave up trying to fix it. It is noisy and a pain to have to try and get into the freezer area to eject it. I have resorted to spraying PAM into the pocket for now but it doesnt always help. The ice maker makes plenty of ice otherwise and the water line/filter is OK.
  • 1 more comment
  • PeteL Nov 18, 2007
    I think my problem is the switch that turns the freezer light on/off. It also turns off the ice maker. If it fails, ice maker will not work.
  • Anonymous Dec 23, 2007
    Drain out the water let it dry, and spray with pam or other non stick spray
  • Anonymous Mar 20, 2014
    new circit board for ice maker and now it sprays water all over freezer
  • 473 Answers
Usually low water pressure to the fridge will cause this problem. Not getting enough water to the ice maker will cause the cubes to be too small and get jammed easier. Check to see if you are using a self piercing saddle valve on your water line. If so change it to a drill type valve. This will increase water pressure to the fridge. New ice makers will not solve the problem.
Posted on Oct 05, 2007
Maytag freezer water leak
Fridge has a design issue. Duckbill drain valve clogs. They have a new ptrap drain replacement but you have to ask for it, as customer service will deny a problem exists. Here is the service bulletin which was supposed to be for internal use only!
Jan 15, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
Ice maker does not shut off makes ice rill jammed then water goes everywhere
It sounds like you have a malfunctioning ice maker that could lead to future problems. The start device on some models of refridgerator for maytag and whirlpool have been recalled. If your appliance was manufactured in the last 5-10 years you may be having an issue with this component. Mine recently caught on fire at this device that is located near the compressor. If you would like to be a part of the petition for a recall on this appliance contact me at
Jun 08, 2010 | Maytag (MFI2568AEW) Bottom Freezer French...
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Regular loud cracking and popping noises in Maytag bottom freezer. New how to resolve
this is unfortunatley a model problem
its the plastic changing temp
and expanding and contracting
Oct 03, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker freexes ice together
maybe too much water going in to the ice maker
Jun 30, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Bottom of Maytag Freezer Ices Up
You have a plugged defrost drain. easiest way to fix it is unload freezer compartment defrost all of the ice, then remove the 2 screws that hold the rear cover in place about half way down the back wall. once this is removed use hot water to flush out the aluminum evap pan at the bottom of the coil. once it is cleared i will usually pur a little bleach in to kill any algae build up.\
be sure to unplug the refrig and use caution not to cut your self on the evap coil as the fins are very sharp..
Dec 16, 2007 | Refrigerators
Maytag MBF2256H Bottom Freezer Refrigerator Logo
469 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
