Question about Coleman Sport & Outdoor - Others
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Posted on Jul 31, 2013
5 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Broken Cable on Pop-up trailer need help
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Posted on Sep 06, 2009
  • 68 Answers
SOURCE: Broken cables to lift roof
http://www.customcylindersintinc.com/camper_trailer_roof_lift_system.htm
This should help, Pictorial and instructions. Also parts available.
Thanks for using Fixya
Jerry
Posted on Mar 26, 2009
  • 37 Answers
SOURCE: best method to repair cracks in the white
"JB Weld" Might Work.. Then Paint Over to match Camper
Posted on Jul 01, 2009
  • 13 Answers
SOURCE: I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
Posted on Oct 27, 2010
How can I get a 2000 coleman sun valley pop up camper owners manual
Unsure if this is the same model: free manual online
https://cdn.shopify.com/s/files/1/0273/4347/files/2000_owners_manual.pdf?13230720448029520186
Parts manuals - possibly different model:
http://www.campersolutions.com/home/coleman-parts-manuals/2000-coleman-popup-camper-repair-parts-manuals
Apr 22, 2018 | Coleman Sport & Outdoor - Others
How to tighten cable on pop up camper
the adjustment can be done by your dealer, contact them see how much it costs.
Oct 26, 2008 | Coleman 10' X 10' Sundome Tent 9160K101
Need 2000 owners manual for coleman niagra pop-up camper
Try this link
http://www.popupportal.com/index.php?action=media;sa=item;in=2985
Apr 23, 2012 | Coleman 10' X 10' Sundome Tent 9160K101
I bought a pop up. On the way home from buying it popped off hitch (apparently the coupler needs to be replaced)- how do I go about repairing (or does anyone know of a place in southe east WI area that...
Hitch: Verify the obvious. 1-7/8" or 2" ball and coupler. Some couplers can be and may need to be adjusted. Look for a screw on the rear side.
Sorry, not much help on the lift system. Although, I rigged a winch up to my coleman instead of replacing the whiffle tree. You may be able to do similar.
Apr 09, 2010 | Coleman Campers Grill
Sep 06, 2009 | Sport & Outdoor - Others
Rockwood pop-up camper.when i try to use hand crank to put it up or down only the back seems to go up not the front
Hello.
You either have a broken cable, or it may have come loose. Gain access to your anchor points and check the cables. Replacement cable can be purchased "by the foot" al Lowe's/similar as well as cable nuts and such Check the axels and spools powered by the hand crank for anything out of whack, like a broken weld on a cable drum, etc.
Best regards, W/D
Aug 17, 2009 | Coleman Campers Grill
I need a repair/owner's manual for 1999 Coleman
Tried googling Coleman? They might be able to help.
Jun 29, 2009 | Sport & Outdoor - Others
Have used 1981 Coleman pop-up camper and the mechanism that raises the camper up is stripped. Either need manual for 1981 Coleman pop-up or any idea where to get the part to fix problem. It's the screw...
My Coleman has the same problem. I can crank the top up but it will not hold in place.
I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
Sep 21, 2017 | Coleman 10' X 10' Sundome Tent 9160K101
The air conditioner on my pop up camper is loud and vibrating
sounds like the compressor in your air conditioner has a broken spring in it,you can not take the compressor apart to fix,has to be replaced(cashy).I assume your camper is shaking,and the noise only happens when you turn on the air.
May 31, 2009 | Coleman Campers Grill
Hard to crank up
May sound a bit tacky but all pop ups are a bit tedious to crank up. In the event this IS NOT your first time to own or operate a pup. I apologize and suggest you post your problem on the pop up times and or the pux webpages. Both are reliable sources for people who have pop up up or small campers.
May 25, 2009 | Coleman Campers Grill
Sport & Outdoor - Others Logo
2,615 people viewed this question
Top Coleman Sport & Outdoor - Others Experts
David Payne
David Payne
Vernon Taylor
Thomas Perkins
Thomas Perkins
Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
