Question about Petzl Tikka Plus
Petzl Tikka Plus Headlamp has a short and is eating batteries
My Petzl Tikka Plus Headlamp, some Batteries corroded in the battery compartment. I have cleaned the compartment with rubbing alcohol, and the actual contact did not get corroded; the lamp appears to work correctly but if the batteries are left in it for more than two days the batteries are dead. There must be a short in it but I am unable to further disassemble to to see if the inner works can be further cleaned. Direction on how to further disassemble it would be appreciated.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
There's really not much that's serviceable in these things. Try cleaning all the terminals again but this time use VINEGAR instead of alcohol which does not neutralize the corrosion as vinegar does. Just dip a q-tip in the vinegar and swab it on the terminals, then with a dry one, swab up the excess. Then install all NEW batteries, do not mix old ones with new ones as the new ones cannot make the old ones work any better than they are used. If they still don't work, welome to the world of cheap products that are intended to be tossed when they quit functioning. Good luck. :)
Posted on Apr 24, 2009
How to open battery compartment on eddie bauer headlamp
Pull on the back piece where the strap attaches. Straight out. It appears! Do the opposite to get it back on. Make sure it's on securely or the batteries will shift out of position and you will be left in the dark.
Feb 12, 2014 | Eddie Bauer Hurricane Ridge LED Headlamp...
FurReal Lulu kitty batteries corroded and rusted battery compartment. Can compartment be repaired/replaced?
You have to clean the contacts that touch the battery with a metal screwdriver, rub them until the metal shines.
Dec 21, 2013 | Tiger Electronics Toys
2 year old, well maintained Myo XP that has never been submerged or been seriously soaked. Yesterday, I turned it on and 1 second later it went out. Batteries are good. Wiring solid. No battery level...
Its a bit late now i know ; although somebody may get some use out of the information 'that' the 'myo xp' has a manufacturers warranty of 36 months (3 years),
mine has gone the same way after 18 months so its about to go ,back to its roots !
Nov 30, 2010 | Petzl Myo XP LED Headlamp
Petzl tikka plus torch repair
I understood that fixya was free from reading the word free all over the place. I wasted my time filling in the form to find out it was not free, but only 7 days free trial but you needed credit card details before. I will not be the first to write this and am tired of being told things are free when they are not. Do not mislead people.
Jan 05, 2010 | Petzl Tikka Plus
My myo xp headtorch has suddenly stopped working. As the bulb can't be replaced, how do I fix it?
Very strange. Mine just suddenly stopped working last night as well. I have changed the batteries, but it makes no difference.
Dec 01, 2009 | Petzl Myo XP LED Headlamp
Facewest quiz
I believe you are looking at power settings, range compairson
Nov 11, 2009 | Petzl Tikka Plus
Petzl Tikka switch is not working properly. Light not steady.
Would you describe the light as flickering and fading perhaps? Are you using rechargable or Lithium batteries?
Here's an excerpt from a Petzl alert put out a couple of years ago. It may shed some light on your problem..
LED light sources are susceptible to being damaged by the use of lithium batteries due to the different characteristics of lithium batteries in discharge. This has meant that some people have had problems with their headtorches failing when using such batteries... Petzl have reported this problem and other manufacturers are expected to follow suit. However this does not affect all head torches...
There are problems being reported over the LED lamps in certain headtorches when used with lithium batteries. Incandescent bulbs will also suffer a reduced burn-time when used with lithium batteries although this is less severe.
This is because the lithium batteries have a higher output during discharge.
The benefits of a lithium battery are the increased burn time, especially at low temperatures over the traditional alkaline batery.
LR6 or AA and LR03 or AAA are the two size of battery litkely to be used in a headlamp.
Petzl are one of the few manufacturers to advise on this at the moment. Other manufacturers products will also be affected.
The following Petzl headlamps should not be used with lithium batteries:
  • TIKKA / ZIPKA range: TIKKINA / TIKKA / ZIPKA / TACTIKKA / TIKKA PLUS / ZIPKA PLUS / TACTIKKA PLUS / TIKKA XP / TACTIKKA XP / TIKKA XP ATEX / TIKKA XP HAZLOC.
  • MYO range: MYOLITE 3 / MYO 3 noir / MYO XP.
  • DUO range: DUO LED 5.
  • SAXO AQUA.
  • MYOBELT 3
  • DUO LED 3.
  • Oct 12, 2009 | Petzl Tikka Plus
    How to replace halogen bulb in petzl duo headlamp
    Easy enough. The grey rippled rubber ring around the glass is threaded. Grab it good and tight and twist anti clockwise and it unwinds like a tank track..
    Hope this helps...
    Sep 22, 2009 | Petzl Replacement Halogen Bulb for Duo
    TI-84 plus DEAD
    There is a chance there is a battery leakage and the contact is spoilt. That's what I'm facing now as well
    Oct 08, 2007 | Texas Instruments TI-84 Plus Calculator
    Petzl Tikka Plus Logo
    992 people viewed this question
    Top Petzl Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Petzl Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
