Question about Plumbing
Trying to take apart kitchen sink to repair leak.
I have a vintage sink with dual handles and a single faucet. After removing the screws holding the faucet handle down, I unscrewed the handle as far as it would go and it does not come off. Everything I've read implies it will just pop off (eventually) so I don't want to force it. Is there a trick to getting these handles off?
    Genius:
  • 1,605 Answers
You may have to force them a little, I believe there are some plumb putty under the faucet and the handle. if you are unlucky, there may be some caulking under the handle and the foucet insteand of plumber's putty.
Posted on Apr 22, 2009
Been trying for many weeks for remove handle to repair a leak.
Take a chill pill, treat your dog nice, take deep breadth, and tell us what it's a handle to.
Jul 05, 2016 | Kohler K-12177-G Fairfax single-control...
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
Kitchen faucet
you have to tell me more is it single lever or hot and cold hot and cold have stems with rubber washers in end they are held in place with a crown nut ( big as half dollar) FIRST AND FOREMOST TURN THE WATER OFF AT THE BASE THIS GOES FOR HOT AND COLD I if you have a single lever faucet you have to remove the handle( also true for hot and cold faucets) after the handle is removed on single lever you have some type of crown ( looks like a rocket nose cones ) usually it is screwed on and holds some type of cartridge or ball anyway you use a wrench called a channel lock or vice grip to take apart i need more info before i can tell you more
Aug 27, 2014 | Plumbing
I have a blanco kitchen faucet that is about 5 years old. it seems to be leaking from inside the unit itself , problem is , trying to figure out how to get it apart to repair it.
behind the handle there should be an allen screw under a crome cap . once you reove the screw the upper metal ring should just unscrew then there are a series of o rings that can be replaced
good luck James
Dec 26, 2010 | Blanco Classic Single Handle Faucet with...
Moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Single handle, about a year old,leaking at the
There will be a set screw on back or under cap on top. Remove handle, next use a phillips screw driver to remove the part that holds on to the cartridge. Then a bonnet that unscrews leaving the cartridge easily repaired or replaced. And there you have it.
Sep 30, 2009 | Plumbing
Leaking Delta kitchen faucet dual handle
Pry the hot/cold button off the top of the handle. Make sure the water is turned off below the sink.
Under the button should be screws. Remove the screws. Pry the handle off. Remove the stems by lifting then out.
That should give you access to the washers you need to change.
Apr 25, 2009 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Repair leaky handle
Try removing cap of knob and tighten screw it could be loose. If that is not it it may need a new seal ring.
Apr 21, 2009 | Plumbing
Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench  and allen wrench  needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Mar 28, 2009 | Kohler Forte entertainment remote valve...
Plumbing Logo
260 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
