Question about KitchenAid KEBV208M Stainless Steel Electric Double Oven
Model: KEBV208M500, 3 years working OK. Suddenly display went off and the oven doesn't work (electrical connections checked OK). I live in Venezuela and called an authorized KitchenAid technician who took the control board out to check it but didn't succeed. I checked with local dealers for a new control board but they don't have it (very poor service here in Venezuela, dealers just sell the product and forget about service. (Forget about spare parts!!!). Can you help me? Jacob Mendelovici j.mendelov@gmail.com
  • j_mendelov Apr 19, 2009
    Can you help me?
    Jacob Mendelovici
    Bati99,
    Thanks for your reply.
    1. According to your experience, can you have a hint about what could have caused the problem and a probable solution.
    2. The kitchenAid model (KEBV208M500) is not any more listed (even it's a three-year old model). Then, in case I decide to order a replacement (say, for the control board), how can I order it?
    Thanks,
    Jacob
  • KitchenAid Master
  • 19,396 Answers
Hi there.
You do not know if it is the control until you test other parts that can be eventually involved. First you need to grab a multimeter and test the parts.
If the oven does not bake or broil, check the following:
Temp probe: This is tested by setting the multimeter to impedance reading, and reading ohms on contacts, if it returns infinite, or a very low resistance, then the probe has blown.
Test PROBE that is part 13 and 14 on diagram below.
Check also if there is a broken contact or a short on contacts to MOTOR-FAN , this can cause the oven not starting. Fan is part 9 on diagram.
Model: KEBV208M500, 3 years working OK. Suddenly - ea2f8ee.gif
Here is also a diagram that can help you in disassembling.
Electronic control board: CNTRL-ELEC this is tested by reading voltages, testing on-board components for continuity and inspecting board. (part 11 on diagram below)
Keypad : Assy, Membrane (Stainless Steel) this is difficult to test , is tested by reading voltages on flat ribbon cable connector to control assembly. (part 5 on diagram below)
To arrange delivery outside US, you will need to contact Partselect by phone, all parts involved are small, and there should be no problem in arranging deliver abroad for a small extra fee.
Should there be any problem you can order same parts by phone from Repairclinc.
Here all parts for this model from Repairclinic.
I use more spare parts sellers' websites , but the two above are the biggest ones, they always have competitive prices on parts, and they have your model in stock. Try giving them a call first.
Do not forget to rate the solution afterward.
Many thanks.
Ginko.
Posted on Apr 19, 2009
  • 88 Answers
You can order the new board at www.kitchenaid.ca (From Canada) or www.kitchenaid.com from the USA. The phone numbers arr used only from those two countries, but I will list them as well - Canada (899) 461-5681 and the USA is (800) 422-1230 and the service number in the USA (800) 807-6777. You can download the entire manual here.
http://kitchen.manualsonline.com/manuals/mfg/amana/kebv208.html
Please post any other questions, I will be available all day and will respond.
    Sergeant:
    Champion:
  • 289 Answers
Hi..sounds like may be problem with the control board.
It may be bad.
check it out..
thank u..
rate me..
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
The oven of my Chef 635 model GSC6635SLP doesn't ignite (no gas comes out in oven, yes from plates), the ignition element is working, there is electricity in terminals connected to thermo valve but it...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 13, 2011 | Ovens
Ive taken element out to replace with new but have forgotten the way the wires went back.there are three spade connections the earth is obvious but not the live and neutral
Hello Ian,
You can put the live and neutral on either of the outer terminals terminal. It really doesn't matter. It's the same principle as not needing to screw in a bayonet light bulb a certain way round. As long as the circuit is complete, it will work correctly.
To put it in the simplest terms, attach the earth wire to the shorter centre terminal with the live and neutral wires on the two outer terminals and job's a good 'un.
Hope this helps. If you need further assistance, please let me know.
Regards,
BElectric
Apr 18, 2011 | Belling XOU252 Electric Single Oven
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Electric oven & grill not working no digital clock display
If there is a display on the clock and you cannot reset it to manual, then the oven will not work, if you cannot reset then you will probably need a new timer fitting.
They can be bypassed, but not recommended unless you know what you are doing..
If there is no display at all , then check to make sure you have supply to oven
Plz rate my solution.
Thanks.
Dec 16, 2008 | Neff U1661 Double circotherm super...
Belling XOU 252 Oven suddenly stopped working
Yes ,I would say that without doubt the element has gone
Elements can go without any warning at all.
Dec 13, 2008 | Belling XOU252 Electric Single Oven
Broiler element Whirpool Accubake electric oven not working
Hello
Welcome to Fixya
My name is Huum,
You need a new top element
http://www.pcappliancerepair.com/model-display.php
You can find the diagrams,schematics, and parts for your range at this site
Please remember to leave a rating before you leave
Dec 11, 2008 | Whirlpool RBS275PD Electric Single Oven
Display doesn't work, but oven works
First turn the electricity off by locating the breaker to the oven and turn it off. Now wait for an hour or so and turn the breaker back on, if the display turned back on, you need a control board (other manufatures call it a clock, PCB or ECC but it's the main elctronic board with the diaplay built in). If it didn't come back on, turn the power off again and make sure all the wire harness's going to the board are connected good. Turn the power back on and it the display still doesn;t come back on you need to replace the main electronic control board. By the way double check the model number and brand because it might be wrong. Please post back.
Oct 04, 2006 | Whirlpool RBD275PD Electric Double Oven
KitchenAid KEBV208M Stainless Steel Electric Double Oven Logo
107 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
