Question about Gestetner DSc224 Copier
Troubleshoot Sometimes the printer jams and doesn't print. It takes oo long to print.
  • 82 Answers
Dear i think you are useing the network printer, you are facing this problam beacuse of bad setting of printer please change your printer setting in print server,check mark on lrp insted of raw and do proper communicate with your printer & server.
Posted on Sep 21, 2007
SOURCE:
Printer keeps jamming even after clearing jam
Hi, most paper jams like this are caused by something inside the printer called a "pickup roller" which is a series of rubber tube/grippy things that are responsible for moving the paper through the printer. If these rollers are dirty or worn down, they don't grip the paper properly and end up causing jams. In larger, more expensive printers, they have maintenance kits that you can buy to replace rollers, fusers, and other commonly replaced parts - but it's probably not practical for this model of printer. You may want to try opening the printer as much as you can (without removing screws) and using compressed air and a lightly-damp-with-alcohol cotton-swab to clean the rollers and other parts that touch the paper.
Jul 27, 2013 | Brother HL 2270DW Laser Printer
At the end of a set of labels, my 400 jammed so I had to take off the front section to clear the jam. When I loaded new Dymo labels, it now doesn't print. Not sure if when I took off the front...
Welcome to FixYa.
Reset the printer by doing the following:While the printer is on, unplug the printer power cord.Restart the computer.Plug back the printer. Make sure all connections are properly connected.Unload an reload the Dymo labels.Then restart the computer again.Try to print.
Thank you for using FixYa.
Jan 04, 2012 | Dymo LabelWriter 400 Thermal Printer
Printer gives mesasage of jammed paper and will not print
Hi Pedro,
This means the printing paper maybe stuck.
  • Turn the printer off and on.This sometimes clears jam automatically.In case it doesn't:-
  • You need to gently pull the paper out from the rear tray or from the output slot.
  • In case it tears,turn the printer off and open the printhead cover and remove the papers carefully not to touch anything inside.Close the cover.
  • Load printing papers again and press RESUME on the printer to print queued print jobs.
Hope this helps.Thanks!
Please rate this answer.
Oct 20, 2011 | Canon iP100 Portable Printer
My Epson 1400 wont pull the paper through when I hit the print button. But when I insert a sheet of photo paper and hit outside printer button it will pull thepaper through but wont print
Hi
First off, the simplest solution is to try to clean the rollers of dust. If you can access the rollers, especially while they are spinning, this would be best. Get a damp cloth either with water or rubbing alcohol and wipe the rubber down, and retest your machine. Most of the time this is cause by the paper pickup rollers, which are made out of plastic or rubber, getting too dirty/slick to properly pick up the paper. Remove all the paper and the paper tray if you can. Using a long qtip, clean the rollers with alcohol. If that doesn't work, or can't be done with your printer, take all the paper out but one sheet. Spritz some alcohol on the bottom of that sheet and smear it out so it covers the entire width of the paper up about 2 inches. Then try to print a document that is a blank page. After either of these methods wait at least 4-5 minutes for all the alcohol to dry before trying to print again.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 15, 2011 | Office Equipment & Supplies
I have a problem with our ricoh printer at work. It is a ricoh aficio AP410N, and the serial # is Q3256500416. It keeps getting paper jams and nothing will print. I called tech support a month ago and all...
Did you try to start with a new pack of paper? Laser printers are very sensitive to humidity of the paper, or a little curled paper. You can start to turn the paper that is in the engine right now upside down. Sometimes this will help. If this doesn't work, than take a closed, new box/package of paper and try again. You might have an environmental problem with your paper. If it works well with the new package, try to store the paper on a better place (not at a window/heater/in a closed box/package etc.)
Jul 07, 2011 | Ricoh Office Equipment & Supplies
Brother HL 1250 Laser Printer Alarm light blinks at same time as ready light and printer does not print - why?
I have saeen this happen and there is usually a paper jam somewhere in the machine. Remember, it doesn't take much of a piece of paper to jam. Use a flashlight and look inside your printer closely. Also check your toner supply level.
Oct 02, 2010 | Brother HL 1250 Laser Printer
Printer keeps paper jamming when i go to print. I
check to see if their is a paper size adj. it might be on legal length si=ze and you are getting 1 and 1/2 sheet duration and then shut down
Jul 31, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
HP Vivera printer won't print
Take the cartridge out and clean the head with dry cloth and reinstall than then try.
also go to menu on the printer and out it back to factory settings.
Kevin
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
76 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
