Question about Samsung SGH-D820 Cellular Phone
D820 shortcut key
My mobiles shortcut key (up key)is not working.all other keys are not able to scroll im using volume key for scrolling up
  • 425 Answers
Re: D820 shortcut key
Try opening your phone and clean its keypad board especially the up key w/ eraser or scratch it a little bit w/ sharp objects and be sure only the gold plated part you scracth...
Posted on Oct 17, 2007
0 characters
3 Points
I want restoret is my mobile is not working
Hi Sai,
Depends on the model and make. Typically, there are steps to reset it completely. Please try the following steps and see if they work.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
Jun 27, 2016 | Cell Phones
Karbonn k775 mobile unlock password solutions
1> Charge the battery sufficiently to support the mobile phone for at least 20 mins (an approx. Tab reset time).
2> Make sure the memory card slot is empty in order to save the content from the memory card inserted.
1> The mobile should be switched off first of all.
2> After this, the power button and the volume up button are pressed together for sometime which in a few seconds takes the mobile in the boot mode. The confirmation of reaching this boot environment is the appearance of the Android robot with its stomach open with an exclamation (!) mark.
3> Let's press the Home button to read the menu available in the boot phase.
4> Navigate using the volume keys and select the 4th option.
5> Now you will select that option by touching the shortcut button.
6> Immediately the factory reset will begin and soon one can read the rest-confirmation on the screen.
7> Now select the reboot option using the shortcut key and wait for some time for the mobile to reboot.
Oct 30, 2014 | Cell Phones
How do i hard reset my virgin mobil htc 3g\4g
turn off the phone, hold the power and down volume buttons, then using the volume up and down to scroll and the lock key to select, go to recovery. wait a little and then a phone with a red triangle and an exclamation mark on it should appear(some of the HTC phones will not get this image, if after 60 seconds it does not appear, proceed to the next step), hold the volume up button then tap the power key, then using the volume keys as scroll again select factory reset and say yes. this will erase all the data on the phone though.
Oct 21, 2014 | HTC Cell Phones
How to turn off text clicking
STEP 1 Press the phone's menu key, located between the two soft keys on the top of its keypad.
STEP 2 Scroll to "Settings" and press the center key to select it.
STEP 3 Scroll to "Ring Styles," press the center key, scroll to the specific ring profile that you are using and press the center key to select it.
STEP 4 Scroll to "Key Volume," select it by pressing the center button, turn the volume all the way down and press the center button to lock your changes.
STEP 5 Press the soft key labeled "Exit" to exit the menu system.
STEP 6 Repeat this process for every ring profile in which you want the keypad not to make sound when you use it.
Motorola Support
May 09, 2014 | Motorola Mobility RAZR V3
How to recover my input power on password in micromax x101 mobile
if your phone is android follow this instructions
1. Switch off the device
2. Hold the POWER key together with at least the down volume key to power the phone and start the resetting process.
3. A command-like window with sometimes a green text appears
4. Use the up/down volume keys to scroll screen and use the Power key to select.
5. Select WIPE DATA and the phone reboots after some few minutes to clear and reset your device memory.
May 05, 2014 | Cell Phones
I have a virgin mobile cell phone forgot locked pattern how to by pass it
  1. Press and hold the POWER key and both volume keys
  2. Continue to hold all 3 keys until an exclamation point and a little green android robot appear
  3. Press the HOME key to display the menu
  4. Navigate using the volume keys
  5. Select Wipe data/factory reset
  6. Use the BACK key to select
  7. Scroll down to Yes delete all user data
  8. Use the BACK key to select
  9. Select reboot system now
Apr 14, 2014 | Samsung Cell Phones
M950 turns on but wont go to home screen
You will need to factory data reset your phone if you are "hanging on startup" (stuck at logo) here is how:
Press and hold the volume up key.
Then press and hold the power key.
When the Samsung system starts release power key
When the Android system recovery appears, release the volume key.
Scroll to:
Wipe data factory reset using the volume down key.
Use the power key to select Wipe data factory reset.
When the options present scroll to "Yes."
Use the power key to select "Yes."
Use the volume down key to scroll to Reboot system now.
Use the power key to select Reboot system now.
Phone should now restart.
Nov 28, 2013 | Cell Phones
How can i connect bluetooth ce0681 to nokia n95
All these given solutions are not catering your problem unfortunately; because your problem seems to be the following "You are not at all able to find your bluetooth headset from your phone, pairing is a far off thing" right?
So, here is the simple solution that no one has given here and on other sites (I myself was confused, but finally found it out):
1. Turn bluetooth of your Mobile on.
2. Put it into "shown to all" mode.3. Now pick your bluetooth device, and simultaneously click on the multifunction key (The middle one that blinks) and the "+" volume key for around 6 seconds or more; you'll see that blue blinking light will become static (and it means that your bluetooth device is now "Searchable" by your phone).
4. Start "Pair new device search" from your Mobile, and your Phone will find the bluetooth device.5. It will ask you for a passcode, just enter 0000.6. Pair both devices now.7. The static blue light (Which became static when you pressed the middle multifunction key and "+" volume key together for some seconds) will now start blinking again (in a 3 sec interval approximately).
Your handsfree is now connected, do a test call and confirm.
In case you find any volume problem, then know that the default volume after connecting a bluetooth handsfree is at low level, so just increase it using your Phone's volume keys/ controls and it shall be all fine.
Vote up if it helps, it is the genuine solution of this problem though; I tested it several times. :)
PS: I'm writing this while logging off in haste, pardon any spell/ typo mistakes. :P
Jan 21, 2011 | Nokia N95 Cellular Phone
Samsung SGH-D820 Cellular Phone Logo
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
