Question about Sony KP-53V45 53" Rear Projection Television
Blue screen of death on a tv??
I've got a Sony KP-53V45, had it for awhile and as most tv's get when they are older it started taking awhile to warm up and turn on. Now when it does come on I have a very blurry picture for about ten seconds then it all goes blue with white wavey lines arcing across the screen. Then after awhile the blue will go out as well and it's all black. Still have sound, but nothing else happens. I've left the set on for about ten minutes after this happens to see if the red and green will come back, and occasionly they will but only intermittently. Any ideas?
  • 105 Answers
Could be the blue crt or the vertical ic on the blue crt board or the focus pack.
Posted on Oct 13, 2007
This could be three differnt things
1. the crt itself could be bad
2.the vertical ic on the crt board
3. the focus pack or focus block
SOURCE:
I want to buy a PS3 and I have a sony kp-53V45 model tv. 1998. will it connect properly?
As long as you have the RED YELLOW WHITE connectors on the back for input, then you will be just fine to connect your PS3 to it.
Aug 31, 2011 | Sony Playstation 3 (PS3) Console
Have a mod # kp-53v45 tv and it wont let me program it to get my cable to run through it, and dont have a manual to it, what to do?
Please open the manual of the KP-53V45 TV by clicking here. To program the channels in the TV, make sure that the cable is connected to the TV using the Coaxial VHF-UHF cable. Select the Auto Program option to program the channels in the TV. Press the MENU button select SETUP MENU and then select AUTO PROGRAM option to scan all the channels in the TV.
Thanks for contacting FixYa.
Jul 16, 2011 | Sony KP-53V45 53" Rear Projection...
Need code to reset tv; tv turns on but cannot
try to check the cables connecting your tv something might be loosed.
Oct 14, 2010 | Sony KP-53V45 53" Rear Projection...
Standby light flashing
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 18, 2010 | Sony KP-53V45 53" Rear Projection...
I cannot get the closed captioned off the screen
I assume you've made sure the captions are turned off on the TV through the setup menu. Are you using this set with a cable box, DTV converter or satellite receiver? Most of these devices have closed-captioning themselves. Make sure you have captioning turned off there as well.
Jul 12, 2009 | Sony KP-53V45 53" Rear Projection...
Tv comes on for a few minutes then goes off
If you take off the front bottom panel of the tv wich is easy. Then you will see 6 tuning knobs at the bottom middle of the tv .the top 6 control contrast for the lights dont mess with those. the bottom 3 are the power to each light.red is bottom left if your screen went blue it makes sense that the red is starting to go but if you turn down the power to it left 1/8 turn it should fix it for awhile .Its easy.
Jan 01, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-53V45 color issues
When ever a tube starts to short or is shorted set always will have over bearing drive lines then shut down like RED if it was bad, set would come on long enough for red lines across set then shut down this is the same with all 3 tubes.Also if you think it might be green tube disconnected green CRT board on neck of green tube if set comes on and plays then it is green tube do all 3 tube this way one at a time this will tell you if you have other problems.
Dec 02, 2008 | Sony KP-57WS500 57" Rear Projection...
Screen Flashing
In a Sony TV, the most common cause of the picture flashing on and off is a weak picture tube. When the set was new, it took about 5 to 10 seconds for the picture to appear once the set was turned on. This is normal. If you have been noticing that it has been taking longer and longer to first appear, this is the clear signal that one of the picture tubes is getting tired. There is a circuit called IK Blanking that monitors each picture tube and adjusts them as the tubes age, so you always see a good picture. When one of the tubes has weakened so much that it cannot produce enough brightness in the picture, the circuit shuts the picture off completely. I guess Sony does not want you to see a tired, dull picture. When the tube is right on the edge of being too weak to keep the picture on, the picture will flash on and off, and it will also take much longer beofre it first turns on. The good news is that the Sony picture tubes always respond beautifully to reactivation (CRT Recharge) but you will need a qualified tech familiar with Sony projection sets to handle that repair for you.
Aug 21, 2007 | Sony KP-53V45 53" Rear Projection...
Open Questions:
Televison & Video Logo
169 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
