Question about Garden
Transmission slips in all the low gears. I cant
Transmission slips in all the low gears. I cant figure out if theres a place to check for gear greese. Are if its just on its last leg.
  • 651 Answers
SOURCE: transmission slipping out of gear
check your tranny fluid.
Posted on Dec 01, 2008
  • 51 Answers
SOURCE: 4x4 slips shiftin gears starting and stopping
you might already know but when shifting into 4wd you can shift into 4hi while driving as long as the tires,(all four) are travelling the same speed. you can't shift into 4wd if you are spinning. 4 low you have to completely stop. When you are in 4 low as you know the power of vehicle is greatly increased due to gear reduction. so if you are seeing slipping symptoms, you might want to change transmission filter. It might not be much help to you but it might prevent problems down the road. also when changing fluid be sure to put mopar transmission fluid for replacement on jeep. like gm calls for dexron. the transfer case on dodge and jeeps also takes transmission fluid. I had to replace a t-case on my friends dakota that was making a grinding noise and it turns out a seal had leaked some fluid out and burnt up some bearings. pretty expensive. they are chain driven. hope I didnt get too carried away, because I am not a transmission expert but I just wanted to share what I did know with you.
Posted on Jan 12, 2009
MrScary66613
  • 1990 Answers
SOURCE: lost all gears while driving this morning
Definately has too be the Problem. There are Marks on there, They may be really Faint though. Get some fluid in there if it is low and hope that it will not need to be Rebuild.
Posted on Jan 18, 2009
sparksflyin
  • 47 Answers
SOURCE: problem with shifting into hi gear, speed surges
check your belt for cracks and chunks missing
Posted on Feb 06, 2009
  • 334 Answers
you may have a bad sencer in the tran take it to a well nown tran shop and have them run a scan on it. to be truthful i pretty shore your tran is on its way out.
Posted on Apr 12, 2009
Gears slip
Automatic Transmission Slipping
www.aa1car.com/library/transmission_slipping.htm
Transmission slipping may be caused by several things: ... there must be enough fluid to generate the internal pressure required to engage the various gears.
Top 10 Signs of Transmission Trouble - HowStuffWorks
auto.howstuffworks.com/under-the.../5-signs-transmission-trouble.htm
It may happen when trying to get into first gear from a stop, or at any point up and down the assorted gears. Common causes include low transmission fluid, ...
10 Most Common Transmission Problems
www.transmissionrepaircostguide.com/10-common-transmission-proble...
A clunking sounds when you shift gears almost always lies within a .... If the transmission is spontaneously slipping in an out of gear (or simply popping into ...
Transmission Slipping - Transmission Repair Guy
Jan 01, 2016 | Cars & Trucks
Transmission not shiftin
For car not changing gears it can be shifter assembly issue, or it can also be transmission issue. Get the shifter assembly inspected with ignition OFF.
For more troubleshooting, I suggest you to get the Following help link checked, its complete step by step procedure to inspect gear shift issues: -----
GEAR SHIFT ISSUES
http://alltypesofpartsreplacing.blogspot.com/2012/11/gear-shift-issues.html
TRANSMISSION GEARS SLIPPING AND FLUID LEAKING ISSUES
Transmission gear assembly and transmission needs inspection. Also check the transmission fluid level. Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot this problem.
I suggest you to refer these links.
Click the link below:-----
2000 Toyota Camry: Transmission slipping and Stuck up?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping?
http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem?
http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating?
http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Transmission fluid leaks near radiator on ford windstar?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Ford Windstar transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
These details will help.
Thanks.
Feb 15, 2013 | 2002 Jeep Grand Cherokee
Replaced 2 3 sol in trans goes forward in all gears
TRANSMISSION REPLACING AND TROUBLESHOOTING
http://alltypesofpartsreplacing.blogspot.com/2012/12/transmission-replacing-and.html
Thanks.
Dec 07, 2012 | 2005 Pontiac Grand Am
1986 olds 88 trans slipping
Transmission gear assembly and transmission needs inspection.Also check the transmission fluid level.Also is the fluid getting leaked or its low.
There are few very helpful links with solutions to troubleshoot these problem.
2000 Toyota Camry: Transmission slipping and Stuck up? http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-transmission-slipping.html
Transmission Slips out of 2nd gear? http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
Car engine Overheats and transmission starts slipping? http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
2006 Ford Explorer: Engine Vibrates and gears slipping? http://whatisbyme.blogspot.in/2012/06/2006ford-explorer-engine-vibrates-and.html
Clutch slipping problem? http://howtobyme.blogspot.in/2012/03/clutch-slipping-problem.html
Dodge Anti slip System is not operating? http://whatisbyme.blogspot.in/2012/07/dodge-anti-slip-system-is-not-operating.html
Ford Windstar transmission fluid leaking? http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
Thanks.
Nov 24, 2012 | Cars & Trucks
Trans starting slipping after modulator replaced
Thanks.
Nov 24, 2012 | 1986 Oldsmobile Delta 88
1995 lincoln occasionally has problems getting in gear to go. Seems like it is stuck in neutral. Lasts a few seconds then it gets into gear and goes.
SEEMS LIKE TRANSMISSION FLUID LOW.TRANSMISSION SLIPPING TRYING TO GO IN DRIVE.CHECK TRANSMISSION FLUID LEVEL. IF LOW ADD FLUID UNTIL YOU REACH FULL MARK ON TRANSMISSION DIP STICK. WITH ENGINE RUNNING A IN OPERATING TEMPERATURE.IF FLUID LEVEL OKAY.CHANGE TRANSMISSION FLUID AND FILTER IF YOU HAVE NOT CHANGED IN A LONG WHILE.A DIRTY STOPPED UP FILTER WILL CAUSE TRANSMISSION TO SLIP.CANT PICK UP FLUID.
Dec 26, 2010 | 1995 Lincoln Town Car
You have a problem with the bands in the transmission. They will need to be adjusted to correct the problem. Also have the transmission filter changed with new transmission fluid. Check the fluid level in transmission first,if low add fluid and test drive. If its the same as before you will need to go to a transmission place to have the bands adjusted to correct the problem. Hope this will help you.
May 23, 2010 | 1993 Dodge Dynasty
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
