Question about JVC AV-32D503 32" TV
Jvc 28gt1bjf tv
How to adjust horizontal hold
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
From remote control first you will have to go to service mode. For that Press (DISPLAY),(CINEMA/GAME)keys you will get MENU now you can adjust hor.hold. if your problem is not solved please let me know so I can send you other code
Posted on Sep 19, 2007
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
JVC AV 60D501 H hold ?
What do you mean jumping, or does the picture look like it is in 3-D?
Aug 10, 2007 | JVC AV-60D501 60" Rear Projection...
I CANT ADJUST THE RED VERTICAL LINES ON MY JVC REAR PROJECTION TV. i HAVE DONE CONVERGENCE AND MANUALLY ADJUSTED THE RED LINES HORIZONTALLY, BUT NO LUCK WHAT CONTROLS TO USE VERTICALLY
If it will not adjust up or down or left and right the convergence chips need to be replaced.
See attached photos of board that is in your set:
This can be a do it yourself repair and the parts do not cost a fortune.
Can I help?
SD TECH
Oct 16, 2011 | JVC AV-48WP30 48" Rear Projection...
My philips 240b powervision tv, about 10 years old, while watching, all of a sudden the screen video turned into slanting horizontal whilte lines. the input is from setup box. I guess it happened when i...
Slanting horizontal lines indicate that the horizontal hold is out of adjustment. As the components age they change values and don't have the same effect on the circuit. some units have a horizontal hold adjustment pot on the back that can be adjusted to bring the horizontal back to the middle. If the adjustment pot is not on the back the only way to bring the horizontal hold back is on the inside of the unit and this is not a safe proceedure. If the picture was really good before it went bad then it might be worth the cost of repair. If the picture was getting weak (light colors, washed out look) then the repairs are not cost effective (not worth the money to have the unit repaired) There are some tv repair people that work quite a bit cheaper than others. It would be worth a few phone calls to get an estimate and make an informed purchasing decision.
May 01, 2011 | Televison & Video
Jvc television AV-28GT1BJF has developed picture problem with the screen split in 2 tophalf ok bottom half blank any ideas ?
Maybe your tv has a defect in the board, the problem is in the vertical ic or loose connection in the board. you need to resolder the board. to fix the problem. but the technician only can do that job to fix the problem.
Jun 29, 2010 | Televison & Video
JVC AV-27730: horizontal bright line across screen in the
it could be an electrolytic capacitor or the vertical output I.C. in the vertical circuitry,if you remove the rear cover tap on the board in different places and see if the picture fills out or atleast jitters like it might fill out,then it could be just a cold solder joint,then remove the main board and resolder all joints and this should repair the condition you have
Nov 18, 2009 | JVC AV-27730 27" TV
JVC 27
Screen and focus adjustments are integrated into the flyback transformer. Take the back off the set and you should see the two little knobs on the transformer. A little tweak of the screen control (it may be labeled "SCREEN" or "G2") will brighten things up. Just be careful. Working on an operating TV, especially in the horizontal output area, exposes potentially lethal voltages.
Nov 10, 2008 | JVC AV27F476 27" TV
JVC AV-28WFX EUS1 unstable image
Hello, I think you have a faulty "horizontal width" or horizontal
linearity preset pot. This pot will be located on the main PCB
and you can adjust it with a small screw driver, when you do the
picture will shift from left to right or vice versa, or move back to fill each side. If it wont hold after making the adjustments then the pots ( potentiometers) need replacing, which means unsoldering them from the printed circuit board( PCB) and take them in to your local radio shop for new ones. By the way you might need 2 pots ( 1 for the WIDTH and 1 for the LINEARITY)
Good luck.
Feb 05, 2008 | JVC AV27F476 27" TV
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
JVC tv have replaced IC's
Did you check the resistors which are near by the IC's.may be one of them is burned
Jan 13, 2008 | JVC AV-56WP30 56" Rear Projection...
JVC AV-32D503 32" TV Logo
124 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
