Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Need pictures of governor springs and governor
Need pictures of governor springs and governor rod assembly for a briggs vangard 26 hp twin cyl engine NEED PICTURE OF SPRINGS AND GOVERNOR
2 Suggested Answers
SOURCE: need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Posted on Apr 19, 2009
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Need to know where the springs hook to the governor arm on a 25hp v-twin intek i/c briggs 445777-0129=E1
The spring goes on the second whole in the govner rod at the bottom of motor.
Aug 05, 2014 | Garden
I need to know where the springs hook on the governor arm on a 445777-0129-E1 briggs 25hp v-twin
on the governor rod there should be a spring that gos around the rod and hooks on both ends of the rod .then theres a spring and its very important that it is the right tension spring,go to a dealer and have him look up the correct spring for that model once you get it the spring will accually make the governor sping the engine wide open till it starts but from the governor arm you should see a holder of some kind or a hole where a spring goes to,thats the best I can do for you without seeing it,the dealer where you get your spring may hae a diagram of it!
Aug 05, 2014 | Briggs & Stratton Garden
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
The govenor rod cannot be adjusted. The springs are intact. Motor revs up but will not idle down. It is 23 HP.
Just guessing here, but if there is no control of the throttle and the engine over revs, then more than likely the governor control is broke. Briggs if famous for that problem. Governor is around 25 dollars and a lower crankcase gasket. Requires the engine to be pulled, lower crankcase removed, remove all pieces of old governor and then re assemble with new governor and gasket.////Before doing all this check that both springs are on the governor on the exterior of motor. If you manually hold the governor arm back, counterclockwise, and it still revs, then you need to replace governor. Don't let it rev for long or it with throw a pushrod or worse. good luck
Sep 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Think i have a problem with governor on my 21hp v-twin briggs. it jumped to max speed and can't get it to slow down. which part of the governoring system could have let go?
Check for a broken spring on the governor linkage, follow your throttle control cable down to where it attaches to the throttle mechanism. In behind where the cable attaches you should be able to see a spring on the governor arm, the spring may have broken or somehow came out of its attaching point. Obviously be very careful about over-revving the engine, it could result in a broken connecting rod and a hole in the side of your crankcase.
Aug 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Apr 18, 2009 | Briggs & Stratton Garden
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
555 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
