Question about Dryers
Dryer wont start
The dryer will not start. Once you turn the timer and press the start button it begins to whine and tries to start. I got it to turn over a couple of times and then quits. If you press start again it does nothing-makes no sound. If you wait 5-10 minutes it will make the whining sound again but I can't get it to turn over at all.
  • 43 Answers
Your motor is bad.
Posted on Apr 25, 2009
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
When I press the start button to begin drying clothes, once you take your finger off the button nothing happens..The dryer drum will turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 26, 2011 | Whirlpool LGB6300 Gas Dryer
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
DRYER WONT START
HELLO THERE:
The most common problems with this problem is that there is a fuse that has blown in the dryer or that the door switch has failed and needs to be replaced or the timer switvch or the motor it'sef has went out (NOT LIKLEY) THOUGH
Or THE dryers push start button is faulty
so please check these things out and replace any parts that are found to be defective
Hope this is very helpful for you best regards Mike
Jan 09, 2010 | Whirlpool ET8CHEXSQ Dryer
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
Kenmore 80 serirs dryer wont start..
hi..check your circuit breaker,may be the power cord
is tripping it.If this is not the problem,check and see if
there is a reset button on the outlet where you plug in
the dryer.
try this out..
thank u..
kindly rate my response..
May 15, 2009 | Kenmore 44832 Front Load Washer
DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Dec 15, 2008 | Dryers
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
148 people viewed this question
Top Dryers Experts
