Question about HP Pavilion dv5000t Notebook
CanI use power rated 19volts instead of original power supply 18.5volts
I have a hp dv5000 laptop I suspect problem with original power supply output 18.5volt 3.54 amp I have another power supply which fits into laptop but has output 19volts 4.74amps---can I use this power supply with 0.5volt higher rating? Could it cause damage? Than Steven
  • smbs Apr 19, 2009
    to the plunge by myself after calculating input tolerances---less than 5%
    all works fine
    Steven
    Novelist:
  • 184 Answers
The following three conditions should be met for you to use this charger safely.
1) Output Voltage is within +/- 5% of your old charger's output.
For example, if your old charger provides 19.5V, then you can use a charger that provides 20.5V or 18.5V.
2) Output Current is the same or higher than that of your old charger.
For example, if your original adapter provides 3.42 Amps, then you can use a charger that provides 3.42 Amps, 3.9 Amps or higher.
3) Connector tip must fit securely into your laptop.
So it would do no harm to your laptop with a 19V 4.74a adapter working on hp dv5000.
Reference: HP DV5000 ac adapter
Posted on Oct 25, 2011
    Novelist:
  • 210 Answers
As you have found... half a volt at that amerage should be just fine...
If it helps, I just bought an aftermarket replacement of the correct voltage and amperage for my nx9010 from eBay for $15AU delivered. It'd probably help when it comes time to sell your laptop =-]
Posted on Apr 20, 2009
I measure the output voltage from the power supply and I have 19volts when I turn th unit th voltage flucuates from 19volts to 2.5 volts and the back lightsjust flicker on then off
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Aug 30, 2014 | Televison & Video
Power
Does the power supply unit produce 19volts? If it does, you may have an issue with the motherboard that will require specialist repair. If the power supply doesn't produce power, replace it. If you can find a friend who has a battery that fits, worth fitting it to check the charger and motherboard.
May 11, 2013 | HP 435768-001 - Compaq Presario C300...
I recently got this laptop from someone who did not have the power supply with it. Can anyone tell me what the required power supply must output? I really don't want to fry this computer, so I want to make...
You need a charger with this features: 90W Laptop AC Adapter / Charger for HP Pavilion DV5-1125NR / DV5-1127CL Replacement
Diameter : 5.0 mm x 7.4 mm
Input Volt Type : AC
Input Volt: 110-220V (Worldwide Use)
Output Ampere : 4.74A
Output Power : 90 Watt
Output Volt : 19V
You can buy one at:
http://www.buy.com/prod/90w-laptop-ac-adapter-charger-for-hp-pavilion-dv5-1125nr-dv5-1127cl/q/loc/101/215845345.html
for $19.89 including shipping.
If this was helpful, please rate me.
Thank you
Jan 13, 2011 | HP Pavilion dv5-1125nr Notebook
Power supply has a continues blink instead of a solid led light.
HP skimps on power supplies, using a supply that has only a small margin of excess power. This causes the supplies to run under stress too often.
Make sure any replacement supply has the correct physical configuration for your system and replace it with one that is capable of 50% more power than the original rating; the cost difference is likely to be minimal and in any case lower than an 'original HP' unit of the same power rating that has now failed.
It is possible that a failed mother board or hard drive is causing your problem but you are risking well under $50 (for an ~400 watt supply) and will be getting a superior unit. eBay is a good source and you can seek a replacement using the Pavilion series name and then checking for your particular model number.
Oct 26, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
Battery with HP Pavillion DV5000 won't work. Do I need to replace the battery or is there a battery charger I could use to recharge the battery? Dianne
You can order a power cable online or pick one up at your local computer store. They should run between $80-150. The battery itself is very expensive to purchase but is rechargeable.
Oct 22, 2009 | HP Pavilion DV4015cl Notebook
I need from HP pavilion dv5000 sound card driver.
i don't know which dv5000 model it's so, here they are
HP Pavilion dv5000 CTO Notebook PC
HP Pavilion dv5000ea Notebook PC
HP Pavilion dv5000t CTO Notebook PC
Step 1: Software & Driver downloads
Step 2: Select Operating System
Step 3: Driver - Audio (Select your sound car brand)
Don't forget to rate my comment.. Thanks!... (=
Jul 05, 2009 | HP Computers & Internet
2 yr old toshiba satellite laptop. Original power adapter stopped working. Replaced with a Targus I got at Walmart. Was wondering if this could cause problems. Thank you
As long as the output voltage from the power supply is the same as what your laptop needs your good to go, but, also check the output "amps" you need the amps rating to be the same or more on the power supply. The laptop will only draw the amps it needs so if the power supply amps rating is higher no problem, but if the power supply amps rating is lower it could cause the power supply to over heat and maybe die on you.
If you are unsure please check with someone familiar with electrical ratings.
Oct 19, 2008 | Computers & Internet
Hp pavilion dv4000 screen is dark and unreadable
hi this is a website where you can dawnload service repair manual
http://www.laptop-repair.info/hp_laptop_repair_manual.html
check with it
regards
Sep 18, 2008 | HP Pavilion dv4000 Notebook
Hp flat screen monitor
It's probably your dc power supply.
Mine would blank just 2-3 seconds after power-on.
I pulled this monitor out of the garbage - someone threw it away. I found any old 12vdc power supply I had laying around (1 from an hp scaner 1250mA, another rated at 600mA) neither could supply the current (amps) required to run the backlights, therefore backlights shutdown, monitor goes blank--monitor stilled powered on, but black.
I tried all of the disassembly, re-solder various solder joints on the LCD Inverter board and removing the heat/magnetic shield from inside the back cover of the monitor. Nothing worked.
I bought a Segate 80gb external hard disk drive that came with a 12vdc power supply, looks like a typical laptop power supply, rated at 3A (3000mA). Plugged it to the monitor, it powered up, and it works flawlessly.
Oct 19, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion dv5000t Notebook Logo
377 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
