Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Dryer motor will not engage
The motor will not start but I can hear the relay click on when start button is pushed
    Sergeant:
  • 236 Answers
Probably the motor start capacitor has gone or the motor is faulty.
Posted on Apr 19, 2009
  • tony howlett Apr 24, 2009
    why is my comment innopropriate? have you found out the problem then? are you prepared to offer any more info on the fault or do we have to mind read? may be a better idea to do just that instead of offering a not helpful statement.
I have a beko condensor tumble,it will only start if I physically push the drum,is the capacitor at fault?
might be could also be the start relay? u can also buy a 3 in 1 hardstart kit pretty cheap more cheap than buying relay or capacitor. EASY TO INSTALL COMES WITH INSTRUCTIONS.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Apr 25, 2015 | Dryers
When I push the start button my dryer only clicks.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
Apr 17, 2015 | Maytag Dryers
Kenmore dryer 3979964
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Aug 26, 2014 | Kenmore Dryers
Kenmore110.620 will not start
Aug 18, 2014 | Kenmore Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Kenmore Whirlpool Dryer Won Start Easy Fix
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Door switch
Jun 24, 2014 | Kenmore 63942 Dryer
When i push the start button i hear a click but dryer wont start
If the click is on the relay then check on the power to the motor, If there is power and it wont turn , the motor can be defective. But if there is no conectivity from the contactor then the controller relay can be faulty.
It will be good to inspect your observations before we can confirm on the exact point of fault.
Please comment.
Aug 31, 2010 | Whirlpool LEQ8858J Dryer
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Will not turn on when I turn to ''start''. I can hear the motor hum but the unit will not start.
i have afrigidaire electric dryer all electronic control panel when i push the start button i hear a click from a relay on the control panel. but does not start or spin.thougth it was the motor i replace it with the new one it still the same.does not do anything
Oct 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start
There is a start relay on the computer control board. You probably hear a very dull click. That click is the relay on the computer board trying to engage, but it won't and therefore your dryer won't spin and your board sends a beep and perhaps an "E11" error code to the LED display (Not sure on Kenmores.).
In plain english, you have a bad control board now and will have to replace it. Cost about $130.
Dec 15, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
149 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
