Question about Kenmore Refrigerators
Water is leaking into the refrigerator.
Water is dripping out from the middle top behind where the light bulbs are. How can we fix it? What could be causing this?
  • 125 Answers
Most likely the defrost drain in the freezer is frozen shut. take out the back wall of the freezer and check under the evaporator. if its a whirlpool built kenmore you may find a sheet of ice on the floor of the freezer under the plastic floor/tray. if this is the case, remove ice, thaw drain with a turkey baster and hot water. wrap a piece of thicker copper wire (pencil lead size approx), around the defrost heater and push into drain about 2-3 inches, making sure it doesn't touch the sides of the drain, this will keep the drain from freezing shut. if its a frigidaire built remove the control from the inside of the ref and silicone around the opening where the water drains from the freezer into the drain cup that is built into the back of the control panel. that will keep the water from running along the ceiling of the ref and dripping. hope this helps. if not put model number with problem.
Posted on Apr 19, 2009
Frost Shows Uo On Rear Wall Control Also Water Drips From Top Middle Section And I Have Water Build Up On Lower Pan-floor ???
Hi friend, thank you for your post!
Based off your post you are having trouble with frost on your rear wall and water dripping from the top middle section on the inside of your Frigidaire refrigerator. Sounds like you may have a possible problem with an air leak or water leak. I would suggest checking your seal to make sure there is no leak. You can do that by placing a dollar bill between the body of the freezer and door. If the bill comes out easily then the gasket may be causing frost to develop due to an air leak. I would recommend exchanging the gasket out. If the gasket is sealing properly then it could be an issue with the water line and you should perform a manual defrost that could help clear out any restrictions in your water line. To perform a manual defrost you would need to disconnect power from your refrigerator for roughly four to six hours. I hope this information is helpful. -Matt
Feb 23, 2015 | Frigidaire Refrigerators
Tip
Water Leaking Inside Refrigerator
If water leaks inside your refrigerator
(and it WILL, at some point) you can fix
it yourself. My 26 year old fridge was leaking
and I fixed it completely. It is a Kenmore
top freezer, bottom refrigerator model.
In the good old models, one had to defrost the
fridge every few months manually.
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assembly, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
With lot of patience (I mean lots of it) you should be saving hundreds
of dollars. Attached are some pictures I took. Call me before you dig !
on Mar 01, 2010 | Refrigerators
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Water leaking from ceiling behind light bulb near water filter in Frigidaire side by side FRS26LF8CS1
On your model the freezer is over the fresh food section and defrost coms about every eight hours. If by chance your condensate drain from freezer above becomes blocked behind that light shield the water from defrost will collect in a cup behind that shield and flow down into the fresh food section. Click Here=> Leaking Refrigerators and once done there click here=> Leaking Refrigerators, Just What May Be Happening If you have any questions about your Refrigerator I will be here or reachable here, Thanks and please rate if helpful, Sea Breeze
Oct 18, 2011 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water is leaking inside refrigerator from back of refrigerator . it is dripping form the(J shaped plastic piece in middle) that holds the light bulb. I have cleaned the refrigerator, ,pulled out the tray...
There should be a drain there somewhere by the J shaped plastic piece you need to pour some hot water down it and follow up with a curtain wire down there too, to clear it out :)
Jun 07, 2011 | Whirlpool Refrigerators
Hotpoint. Water is leaking from behind light bulb
The drain hose in the back of your freezer is frozen shut. The water you see is coming from the defrost cycle. Turn off the refrigerator. Remove the floor from your freezer and remove/thaw all of the ice. Locate the drain in the back of the freezer. It may be behind the back panel. Thaw the drain until water flows freely through it. Reassemble the freezer, and you are back in business.
Oct 22, 2009 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refridgerator ice maker leaking water
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 17, 2009 | Whirlpool ET4WSKXS Top Freezer...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water leaking inside of the fridge from the top
It sounds like your frost-free freezer is cycling through its normal defrost mode, which allows the cooling assy. to be deiced and that melted ice (water) will run out and down to the drain in the bottom of your fridge.
Aduz
Mar 27, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water leaking inside of refrigerator from freezer
IT SEEMS LIKE YOU HAVE A CLOGGED DRAIN . CHECK YOUR CONDECER COILS BEHIND KICK PLATE .. AFTER THAT YOU CAN UNPLUG FRIDGE FOR 24 HRS WITH DOORS OPEN AND SOULD DEFROST ENOUGH TO CLEAR DRAIN . IF NOT . DEPENDING ON MODEL YOU SOULD BE ABLE TO GET THROUGH DRAIN THROUGH MOST FREEZERS .
Feb 03, 2009 | Kenmore Refrigerators
Refrigerators Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
