Question about Rosen CV1010N Car Monitor
Vertical Hold doesn't Hold
Entire picture slowly scolls up...followed by another then another and another... Never seems to hold where it should. Makes watching it very annoying! This happens with and without a DVD playing, or even in the player. Picutre starts to scroll soon after monitor power is turned on
    Genius:
  • 1,139 Answers
This would denote some kind of vertical sync problem. I would begin by checking the vert sync circuitry. To do this you will have to have an Oscilloscope, and DVD containing a steady-state picture. The oscilloscope is used to measure the vertical sync rate and the vertical sync pulses. Taking into mind that ther is a video signal present but it is in the black range. If you do not have an oscilloscope it makes troubleshooting this hard. in any event you will also need a schematic to see what waveforms you should be seeing. If you do not have a background in electronics you may have to have someone who does look at this unit.
Posted on Sep 19, 2007
SOURCE:
My Kyocera mita 2530 copier shows system error C6000 and will not operate
May be a fuser error.
Try....
Switch off
Open Toner Cover
Switch on, holding "System Menu"
Go to "Secure Setting"
"Enter"
Hold "Start" "#" "Enter"
Scoll down to "Maintenance Mode"
"Enter"
Scoll down to "U163"
Scoll do "Execute"
"Enter"
Close Toner Cover
Leave run for a few seconds
Switch off
Switch on
Oct 28, 2017 | Kyocera Office Equipment & Supplies
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Aug 21, 2014 | Televison & Video
Kyocera eroor code c-6000
Works with ERROR C6000, C6300, C6400
Switch off
Open Toner Cover
"Enter"
"Enter"
Scoll do "Execute"
"Enter"
Close Toner Cover
Switch off
Switch on....
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
May 04, 2014 | Kyocera Mita 2 Pack Km 2020 2035 2050...
ERROR COD C6000
Switch off
Open Toner Cover
"Enter"
"Enter"
Scoll do "Execute"
"Enter"
Close Toner Cover
Switch off
Switch on....
May 04, 2014 | Kyocera FS-1118 Printer
Vertical lines that scoll the screen picture.
Ok this problem is coming from either your tv sets vertical circuit or the tuner itself is faulty, most likely the problem is coming from your vertical circuit with bad solder on the vertical ic or you have a faulty capacitor which can also cause this problem what i would suggest unless you have electronic experience on troubleshooting electronic components is to take it to near by tv repair shop and have then troubleshoot this circuit to see which component is giving you this problem, thank you,hope this helps.
Aug 11, 2009 | Mitsubishi VS-50705 50" Rear Projection...
How do i UNINSTALL MY ge spacemaker xl
TIP: Go to the web and type www.partselect.com enter your model number then scoll to page 4 of 7 and when you come to BACK COVER, click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. Part number 993 is the mounting plate attach to wall. Open your cabinet doors above microwave, have someone hold it, and remove the screws going through cabinet into top of microwave. Pull down and out slowly towards you until the unit slides off the support arms. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need help with removal
TIP: Go to the web and type www.partselect.com enter your model number then scoll to page 4 of 7 and when you come to COVER PLATE, click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. Part number 993 is the mounting plate attach to wall. Open your cabinet doors above microwave, have someone hold it, and remove the screws going through cabinet into top of microwave. Pull down and out slowly towards you until the unit slides off the support arms. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
Vertical hold problem
Maybe sync separator transistor is faulty
Dec 22, 2007 | Zenith C32A26 32" TV
Vertical hold not working
on mitsubishi just replace the caps that are near the vertical ic this will fix the problem good luck
Nov 02, 2007 | Mitsubishi WT-46805 46" Rear Projection...
Car Audio & Video Logo
226 people viewed this question
Top Rosen Car Audio & Video Experts
Pierre Laplante
rd2xpld
Are you a Rosen Car Audio and Video Expert? Answer questions, earn points and help others
