Question about Garden
My Yard Machines MTD blade won't engage. The belt that spins blade is loose when I try to engage deck.
  • 1 more comment
  • Anonymous Apr 25, 2009
    I am having the same problem. Any help would be appreciated
  • Keith Parker May 11, 2010
    Do you see an arm with a small pulley on it...trying to put tension on the deck belt when you engage the blade???and check this without the engine running
  • COUGHY_MAN May 11, 2010
    Has the mower sat up for a long time?
My mtd 20 hp mower, blade will not engage, found a large spring and a small metal piece that came off and I have no Idea where it goes in order to get this blade going again, can some one give me some info Please..
Posted on Aug 12, 2011
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
When I lower my yard bug mower deck, the engine dies. It runs fine until I lower the deck. Help!!
when the deck( blade) is engaged it puts a load on the engine. that tells me theire is some type of bolckage to the belt/force of the movement and is keeping the engine of moving freely. check to see if there is any blockage of the blades, or the belt is loose or off track.
Jun 13, 2011 | Mtd Garden
Mtd ride on mower cutter blade belts smoke when engaged
probably a bearing out on one of the pulleys. Disengage turn motor off try spinning each one by hand, you may be able to feel the bad one. You may see discoloration on bad one but probably not with deck on machine.
Sep 29, 2010 | Yard Machines Garden
I have a 20 hp MTD Yard Machine with a 46 inch deck. I was cutting some thick overgrown grass today and the belt started smoking. I immediately disengaged the PTO gave it a minute and tried to re-engage...
you should take a picture of how the belt is on there now so you will know how to put it back on. check to see if the blades will spin freely with it not running of course. put your hand under it and spin the blade. if they don't spin you may have something wrapped around the spindles causing the blades not to spin causing the belt to smoke. if the belt is cracked or missing any chunks you may want to replace it. take a picture so you will remember how it goes back on.
Sep 18, 2017 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
How do I change the blades on a mtd yard-man 42" riding mower
u do not have to remove the deck. all u need is a floor jack and some air pressure because the bolts may be very tight u will needs either a 7/8 or 13/16 socket and they come off normal lefty loose righty tight. good luck
Jul 08, 2009 | Mtd Products Yard Machines 158CC Tiller
John deere mower won't engage
on the engine there is a shaft with 2 pullys ,drive belt goes to the top closet to the engine lower pully is for the deck
there also is a saftey switch located on the deck which should shut down blade operation when raised. check the mandrels for broken bearings by grabbing the pully and wiggle them back and forth looking for movement could be possible that one madrel is shot giving you that bad sound which is crushed bearings
Jun 30, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
The newly purchased deck belt turning the blades is extremely loose
If idler is in tact and spring attached, it is likely that the belt isn't routed properly. If you try to route the rear-most portion of the belt around the idler, it will be loose. You must route the front-most portion of the belt around the center blade pully and then around the idler. Just Google "MTD 46 inch deck diagram" and you will go to a Parts Tree site with the proper diagram showing routing.
May 26, 2009 | Mtd Garden
Garden Logo
774 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
