Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
Center water tower came apart
The center water tower in the dishwasher seems to have three nesting pieces that extend upward. One day I found one of the pieces on the floor of the dishwasher after I ran it. It was a 4" piece with a hole in the center at the top and three holes going around the top. I figured it should go back into the center of the tower, but the lip on the bottom of the piece won't allow me to put it in. Please help!
  • killerbee6 Apr 19, 2009
    The exact model # is HDA3400G02BB. I will try to take the spray arm and tower assembly off and try to see what you're talking about. Thank you so much for your help!!!!!
  • Anonymous Mar 24, 2014
    I found my spray tower at the bottom of the dishwasher after I ran it... how do you reinstall
  • 1,543 Answers
There have been many versions of the spray tower used over the years. If you have the model HDA3400G which you posted under, you should get a part number WD22X10008 which is the lower spray arm and tower assembly. By looking at the new part, you will see how a couple tabs hold the part on, and can figure out how to remove the old one with a flat blade screwdriver (or two). If you have a different model, please post the exact model number. The model number sticker is generally located on the left side wall of the tub, right by the front.
Posted on Apr 19, 2009
Water intake seems less and motor noisy
1- water intake is where water supply line is connected to d/w on bottom left be hind kick plate
2-remove spray arm and upper spray tube at same time turning to the right then you will have to use a torx driver to remove sump Cheers
Dec 10, 2013 | Amana 24 in. ADB2500AW Built-in Dishwasher
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
The center tower is not able to go all the way down after a cycle
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
l;
Jul 17, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't drain. (Kenmore 3380957Rev A) It's been not draining that well for a couple of months, but then a couple of weeks ago, it just won't let the last inch of water out. --I can't see in...
The problem could be the pump, the drain hose or the timer. It will not drain if left to sit. The thing to try first is to put a cup of white vinegar in the machine and let it wash. This may remove sludge or scale blocking the strainer. 2nd take the hose loose at the sink drain and see if it is half clogged with grease or food. Check the hose and the nipple. Last, if it does not work take the bottom off the dishwasher. 4 screws and a plate. look for the pump and see if the hoses are clear. Sears will sell you a manual to repair and test this machine at its Parts Central on line
Jun 24, 2010 | Dishwashers
GE GSD2200G02WW problem
Did you have any luck? I'm in the same jam... It seems like the piece is sealed into the tub of the washer...
Jun 23, 2009 | GE 24 in. GSD2220Z Built-in Dishwasher
Washer arm is all clogged up.
Hi Bob: The center of the arm screws out, is it the top or the bottom? I have a Maytag as well, once you unscrew the center piece the arm shoul come off, there will be a clip in the center, all you do is depress the tabs along the side and pull out. The bottom is similar as well. I hope this helps.
Apr 19, 2009 | Maytag DWU9962 Dishwasher
How do I open the center console on 2002 Lexus ES300?
you will have to take most of the drivers side of the dash out to get access to the panel behind the ashtray ,
Jan 04, 2009 | 2002 Lexus ES 300
Ge dishwasher hums but will not work. is a 1999 model,,seldom use
When you use your dishwasher so infrequently the water inside evaporates and allows the pump seal to dry out, so there is no longer the lubricating water there. You may be able to solve this by pouring a couple cups of hot (not bioling) water directly into the center of the lower wash arm (center spray tower) and letting it sit for several minutes.
If that does not work, you can take the bottom panel off and turn the fan blade on the motor by hand until if turns freely. (don't do this with power to the motor or you may have some nasty banged up fingers !)
To prevent this from happening in the future, keep some water in the dishwasher by poring a bit in every now and then, or by running a fill and pump cycle at least once a week or so. If you are away for extended periods, you can try adding RV antifreeze to the dishwasher while away.
Nov 16, 2008 | GE Dishwashers
Water tower
I had the same problem finding a Water Tower laying in the bottom of the dishwasher. Solution is to simply lift the bottom rack and insert the tower into the center-most square hole. Twist the tower with the large lip on the bottom of the rack and the two plastic pieces will overlap two sides of the square hole. It will come lose again in time, but just reset it again.
Dec 24, 2006 | Kenmore 17439 Built-in Dishwasher
Dishwasher needs repair
Bonnie, the spray arm itself will have a tower that extends upward. On the lower rack in the center will be a tower protector and the upper rack should have a water diffuser in the middle. The protecter and diffuser will clip on to the center of the racks. Hope this gets you going..
May 28, 2006 | Roper 24 in. RUD5750DB Built-in Dishwasher
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
229 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
