Question about Black & Decker String Trimmer Cordless 12" 18V
Black & Decker GL720 Strimmer not working
There is power in the machine but the housing/spool is not rotating at all.
  • frate_mate May 03, 2009
    I have the same problem with my timmer - there's power in the machine, and I can hear the motor spinning, but the spool itself does not spin. The model number of my machine is a B&D NST2018.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    that number gl720 is not in the b&d line up do you have a differant number
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 4 Answers
Hi there, I just thought I'd mention that I also have a Black & Decker GL720 with the same problem. I'm pretty sure it is less than 1 year old too, so well within the 2 year manufacturer's guarantee here in the UK. I think it may be a UK specific model and the phone number from MrFixIt looks like a US number.
I have tried taking the plastic casing apart, but with no luck, as the two halves won't come apart easily, even after removing all the screws. Ah! OK, I've found out the reason that it wouldn't come apart now, there is a screw hidden under the 123 sticker.
It's all apart now, and I see what is wrong, there is a belt running between a small cog and a large cog, and in my case the large cog has partially melted and the belt has come off. Unfortunately, I'm not sure I can get the replacement part now. Hopefully with yours, MrFixit, the belt might have just slipped off, fingers crossed.
Anyway, here is a service diagram of it in case it will help anybody, but as you will see it says only certain parts can be ordered. If anyone locates a supplier of all the parts please post it here.
Many thanks
Simon
Posted on Jun 03, 2009
  • Simon Elder Jun 04, 2009
    OK, I've got this sorted under the manufacturer's 2 year guarantee now. If like me you have lost the receipt, there is a date code stamped on the back of the handle which will enable the authorized service dealer to mend it, providing it is within the 2 year period of course. To find your nearest authorized dealer either go tohttp://www.2helpu.com or ring in the UK 01753 574277
Belt came off so and I couldn't see the part that seem to be missing that kept the belt on. A nut, bolt and a wash sorted it for me. Fitted to the small drive cog. Simples. When dismantling - remember there is a screw under the sticker!
Posted on Jun 19, 2010
    Welcome Back:
  • 4 Answers
Toss it!!!! rubbish
Posted on Jul 14, 2013
Black decker troubleshooting
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
May 20, 2014 | Black & Decker Irons
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
The motor works but strimmer does not rotate
If the head does not turn, but the motor runs freely, then the reduction gear is damaged. It is inside the motor housing. If the motor tries to run but does not rotate, then there is likely material bound up between the moving and non-moving parts.
MANUAL:
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
PARTS:
http://www.ereplacementparts.com/black-and-decker-grass-trimmer-parts-c-4167_9518.html
Apr 02, 2010 | Black & Decker Garden
How do i replace strimmer wire on a black and decker 315
how do i replace a spool and line on a black and decker GL20 strimmer x
Sep 10, 2009 | Black & Decker Garden
How do i refill spool
how do i undo spool on black and decker auto strimmer d825
Jun 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
Jun 19, 2009 | Black & Decker Garden
Got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Jun 01, 2009 | Black & Decker Garden
Black and decker GL720 strimmer
you should be able to order it at a local service center or you could try online at www.jackssmallengines.com they have good prices and a very large inventory
Sep 21, 2008 | Garden
BD GL720 strimmer
Yes it can be repaired Jim. The belt has probably snapped. It happened on mine. Just undo all the screws and one hidden screw underneath the black lable near the number one, which is on the same side as all the other screws. Run your finger over the lable and you should feel it. Just pull the telescopic arm out and lift up the motor slightly so that you can place a new belt on. Simple as. Hope this helps
Jul 10, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
2,815 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
